Mercedes Quality Question - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 10-26-2003, 03:05 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 714 Post(s)
Re: Re:
IMHO, I think the ML is the ugliest thing on the roads these days, though there is a funny looking notchback that MB makes that comes in second.
I must say that on my W123, every piece of wood trim has fallen off and has had to be re-glued. Well at least they're real wood. Sadly the A/C panel wood piece had warped to the point when I tried to straighten it, it cracked!
Oh, come on now! Surely the Pontiac Aztec is the ugliest vehicle on the planet. Have you ever seen one in bright yellow? I swear you might to stone without proper eye protection.
Ron
http://germanstar.net
GeeS is offline
post #12 of 16 (permalink) Old 10-26-2003, 03:20 PM Thread Starter
lietuviai's Avatar
Date registered: Mar 2003
Vehicle: 84 230CE & 84 300DT
I forgot about those Pontiacs but I still don't think they're uglier than an ML, at least ...
I forgot about those Pontiacs but I still don't think they're uglier than an ML, at least to me.
Uglyness is in the eye of the beholder.
~DJ~
1984 300D 173K with 145K on engine
1984 230CE
OBK #29
lietuviai is offline
post #13 of 16 (permalink) Old 11-21-2003, 08:11 AM
Date registered: Nov 2003
Vehicle: E320
Re: What quality?
Take time to view through the "ML" forum and see the list of recurrent problems people have had with this abomination.
50 ML Problems in 4 Years.
I had to return the vehicle on 20 or more occasions to Autonation (the dealer) for warranty repairs. All Mercedes is willing to offer as compensation is $1000, when purchasing a new Mercedes. Despite the many defects Mercedes Benz has not offered to repurchase the car.
The problems included a defective brake system, a defective electrical system, a defective navigation system, a defective washer system, a defective AC system, defective locks, defective trim, defective doors, windows and sunroof and a defective entertainment system.
In addition it often took 1 month to get the vehicle serviced. Often the dealer did not fix the problem on their first attempt, resulting in having to return the vehicle again for repair of the same defect.
I have attached a more detailed list of the problems below.
I get the impression that 1 out of 4 have many problems (not a formal survey).
50 Mercedes Problems in 4 Years
1. Brake system defect (pump leak)
2. Wiper motor defect
3. Door problems (latch noises)
4. Door problems (maladjusted door)
5. Command center malfunction (dead navigation system)
6. Door lock malfunction (right rear door actuator)
7. Washer reservoir leaking
8. Lamp switch defect (stop lamp)
9. Fuel filter problem
10. Door lock malfunction (gas door actuator)
11. AC problem. (AC fan speed switch knob malfunction)
12. Door lock malfunction (gas door actuator)
13. Trim problem (sunroof seal fell off)
14. Door problem (Rattle from inside left rear door - loose metal washer)
15. Trim problem (3rd brake lamp cover pops off even when re-secured
16. Trim problem (rear inside trim panel defective)
17. Window washer nozzle defective on right side
18. Command center malfunction (dead navigation system)
19. Door lock problem
20. Lamp problem (defective check engine light - right rear 02 sensor)
21. Rotor in rear changed at only 27500 miles
22. Sunroof shade problems
23. Sunroof guide clip missing
24. Sunroof shade problems
25. Trim problem (left outer seat trim cracked)
26. Sun roof frame defect
27. Seatbelt jammed (left rear)
28. Brake system defect (pad wear sensor defect)
29. Defect fuel door lock actuator
30. Rear door latch replacement
31. AC problem (system not cooling properly)
32. Sunroof motor connectors rattling
33. AC problem (blower motor rattle)
34. Window problem (switch bad)
35. Command center problem (CD changer error)
36. Window problem (clicking front left window)
37. Door lock problem (rear right/left door actuator defect)
38. Door problem (insulation inside right door damaged due to melting glue)
39. Command center problem (CD changer error)
40. Trim crack (leather on steering wheel cracked)
41. Door problem (rear right/left door actuator defect)
42. AC problems (blower rattle)
43. AC problems (clicking sounds)
44. Trim crack (cracks in duct tape on door)
45. Door problem (rear left door actuator defect)
46. Washer reservoir crack
47. Right window washer nozzle defect
48. Lock problem (front left door actuator defect)
49. Car manuals taken from my car during service
50. Power steering problem (replacement of clamp for power steering hose due to possible fluid loss at radiator)
2004 E320, Black Opal
tcpgv is offline
post #14 of 16 (permalink) Old 12-08-2003, 12:40 PM
Date registered: Aug 2003
RE: Mercedes Quality Question
Hate to be brutally honest. These days, Mercedes just <censored>. However, since their sales figures are climbing, no one cares about the quality issue. What is everyone thinking nowaday.
Check this out
http://just-auto.com/news_detail.asp?art=42987&dm=yes
zero45888 is offline
post #15 of 16 (permalink) Old 12-26-2003, 02:35 AM
merc300e's Avatar
Date registered: Apr 2003
Vehicle: W124 300e
Re: What quality?
dam tcpgv, dats alot of problems u've had!
will
merc300e is offline
post #16 of 16 (permalink) Old 12-26-2003, 10:03 PM
Date registered: Dec 2003
Vehicle: 1994 E320 Sportline
Send a message via AIM to idiosyncratic1
I just think Mercedes Benz is no longer Mercedes Benz the premier car company, but a division of Diamler Chrystler, just another corporation. And all Corps want is profit, how do you get profit, cut on spending.
I sure hope Mercedes wakes up, i miss their old quality. I dont know if i could go any newer than my 94 E320 Sportline on a benz. I mean ya, they still produce great cars that are leading safety, technology and design wise, but its all the little things that they are messing with or not bothering with i should say. Thats what Mercerdes is supose to be famous for, the little things which really only a driver would notice.
I am sad to say, i probably wont look at a Benz for my college car, as of now I am looking at Audi and maybe BMW. And i have been inlove with Mercedes ever since i could say their name.
idiosyncratic1 is offline
