380 SE - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-30-2002, 06:13 PM Thread Starter
Date registered: Dec 1998
Quoted: 2 Post(s)
380 SE
I have an 1985 380 SE and the fan for heater works sometimes and some times not is their a sensor or something i should chech out the drivers side power sear is the same way sometimes it works and sometimes not there is no rhime or reason, any idea`s. Also the cooling fan comes on sometimes and somtimes not.<br> <br> Thanks
Guest (MBNZ) is offline
post #2 of 4 (permalink) Old 05-31-2002, 09:59 AM Thread Starter
Quoted: 2 Post(s)
Re: 380 SE
For your heater fan, I had the same problem on my 380SL. My solution was to take the unit out, blow away all the dust and lubricate the motor. Works fine now. <br> <br> As for your cooling fan, a sensor on the top front of the engine governs it. Once the engine gets to a certain temperature, the fan should come on. The fan should also come on when the A/C is on. Your sensor might be bad. Since the sensor is on the top of the engine, there, also, might be air in your coolant. Something else to check.<br>
post #3 of 4 (permalink) Old 05-31-2002, 11:33 AM Thread Starter
Quoted: 2 Post(s)
Re: 380 SE
I`ll check those things out, Thanks !
post #4 of 4 (permalink) Old 07-24-2002, 06:09 AM Thread Starter
Quoted: 2 Post(s)
Re: 380 SE
Could it be a loose fuse, bad earths, etc?
