350 SL - can't open the engine trunk anymore! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-05-2001, 06:14 AM Thread Starter
Date registered: Dec 1998
Quoted: 2 Post(s)
It was becoming more and more difficult until it became impossible to open it, even after putting oil on the lock several times. Everything looks ok, including the inside command and the remote cable. Is this a common problem on these cars? Thanks !
Guest (MBNZ) is offline
post #2 of 5 (permalink) Old 02-15-2001, 11:47 AM Thread Starter
Quoted: 2 Post(s)
Re: 350 SL - can't open the engine trunk anymore!
What part is hard to operate? The cable pull or the secondary lock at the front of the engine "Hood"? If it's the cable, they can become contaminated or stretched out. There may be a way to adjust it if it's stretched too far. Please advise. <br>Steve<p>
post #3 of 5 (permalink) Old 02-22-2001, 05:23 AM Thread Starter
Quoted: 2 Post(s)
Thanks for answering, Steve.<br>It's difficult to tell. The cable pull and the secondary lock seem OK when I operate them. But thinking about it now, I realize that I don't hear or feel"clic!" or "tchonk!" indicating the first unlocking when I pull the cable at the maximum (but should there be one normally? I don't remember). Therefore, it's likely that the cable is stretched out.<br>Thanks in adavance,<p>Mika<p><br>: What part is hard to operate? The cable pull or the secondary lock at the front of the engine "Hood"? If it's the cable, they can become contaminated or stretched out. There may be a way to adjust it if it's stretched too far. Please advise. <br>Steve<p><p>
post #4 of 5 (permalink) Old 03-09-2001, 01:58 PM Thread Starter
Quoted: 2 Post(s)
Have seem MB cables having an end fitting that spins, walking out the cable. If you can get to yours, this may do the job. Let us know when you get it open.
post #5 of 5 (permalink) Old 03-15-2001, 07:19 AM Thread Starter
Quoted: 2 Post(s)
It worked perfectly! The only illogical thing of this, is that you have to open the trunk first to have access to the cable end, and therefore set the tension right...2 friends were necessary to unlock the thing !!!<p>Thanks a lot Steve,<p><br>Mika <br>
