touch up paint - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 10-18-2016, 05:19 PM Thread Starter
brian92647's Avatar
Date registered: Oct 2016
Vehicle: 2010 c300
Quoted: 2 Post(s)
touch up paint
I need to touch up some small rock chips. Where would you guys recommend for getting touch up paint online?
brian92647 is offline
post #2 of 15 (permalink) Old 10-18-2016, 07:09 PM
Kajtek1's Avatar
Quoted: 1248 Post(s)
For rock chips order one of the pens.
Ebay has good prices, but long shipping from China.
When you shop at US sellers, you get impression that those pens are made with gold.
brian92647 likes this.
Kajtek1 is offline
post #3 of 15 (permalink) Old 10-19-2016, 10:28 AM
Date registered: Dec 2009
Vehicle: 1997 E300D
Quoted: 22 Post(s)
your best paint for stone chips is a system sold by DR Color Chip. It is designed with stone chips in mind. They have a special paint matched to your color code that you smear into the chips and let it dry. You then use a special cleaner to clean off the excess and level off the paint in the chip. It looks professional. It seems expensive but you are paying for the system. After using it, I will not use anything else. No more blobs of paint on every chip. It is at drcolorchip.com .
nelbur is offline
post #4 of 15 (permalink) Old 10-19-2016, 05:38 PM Thread Starter
brian92647's Avatar
Vehicle: 2010 c300
Quoted: 2 Post(s)
any recommendation for getting paint spray can online?
post #5 of 15 (permalink) Old 10-19-2016, 07:06 PM
Date registered: Jul 2005
Quoted: 1085 Post(s)
Yes there are. MB actually sells spray paint for recent color codes. It runs about $30 per can.
If they do not have it then paintscratch.com does a fantastic job matching colors. However if you are at the point of needing to spray paint on an area of the car then please pause.
The entire area including a blend area will need to be sanded lightly so the spray paint sticks. You will need to practice blending into an existing paint finish. Then wet sand the paint
to make sure there is minimal orange peel. Once all of that is done then the new paint will have to have at least two coats of clear coat. Then once again wet sanding to make it very smooth.
Once that is done then a professional polishing compound with a powered polishing tool will be needed. After all of that is done a polymer sealant should be used. After a 2-3 weeks then that
area can be washed and waxed as normal.
If you are working on plastic like a bumper then it all has to be sanded and primed with a flexible plastic primer before the color coat goes on.
You started by saying just touching up rock chips. There is no spray can on the planet that can do a better job than the original MB touch up paint for chips.
Noodles is offline
post #6 of 15 (permalink) Old 10-19-2016, 08:50 PM
Kajtek1's Avatar
I bought MB spray can and it doesn't match the car silver.
I know silver metallic is hard to match and the paint fade over the years, but even I repainted whole bumper, you can see difference between the panels.
For my latest project I bought a quart of paint on ebay and using my HVLP gun it come pretty good .
You always will see difference between new and old paint, but I think it is as good as it can be.
But again, for rock chips get the pen.
Kajtek1 is offline
post #7 of 15 (permalink) Old 10-20-2016, 05:51 AM
Trevor Hadlington's Avatar
Date registered: May 2016
Vehicle: 1989 W124 260E Saloon.
Quoted: 111 Post(s)
Find a paint mixing company, to mix you up a rattle can, to a part off your car. I took a piece of my old wing , .Its done by computer so colour is spot on .
Trevor Hadlington is online now
post #8 of 15 (permalink) Old 10-20-2016, 12:56 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 89 Post(s)
If you have rock chips, using a rattle can may not be the easiest or best way to go. I have seen good results from Dr. Colorchip. I hear it is bit messy when applying but the end results spoke for themselves.
Mike
Michael Pillay is offline
post #9 of 15 (permalink) Old 10-20-2016, 12:56 PM
I do use a local company for making rattle cans. They do have a nice color reading tool and then mix based on the tools measurements.
Noodles is offline
post #10 of 15 (permalink) Old 10-20-2016, 12:57 PM
It does work very well. It is a bit messy, but the results are very impressive.
Noodles is offline
