The mercedes overheating flowchart - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 09-16-2016, 10:29 AM Thread Starter
Date registered: Nov 2013
Vehicle: 1996 C220 2007 ML320 CDI
Quoted: 193 Post(s)
Originally Posted by Kajtek1 View Post
Than again, your experience is different than mine.
That was pretty obvious in W124 section. Where after checking everything else, the owner would disclosure running on inferior coolant.
Bottom line, your chart might have good use on newer cars, where the problem is mechanical or electrical malfunction.
On aged cars, that we usually discuss in the sections I frequent - the most common problem is chemical build up and my first suggestion is get infra-red and read the radiator temperatures.
Meaning what you put as 7th on your priority ladder, would be the first step for me.
Just real-life variations.
That's fair, but if the rest of cooling system is good already, you pretty much end up rather quickly to the radiator. Chemical build-up can indeed be a problem. But using the correct coolant for your car throughout the lifetime of the car would never result in chemical buildup. The 2 big no-nos in using coolant is 1. Using the wrong coolant, you should ALWAYS be using something that's been approved by mercedes or 2. mixing coolant. You should never mix coolant, if you can't find the coolant that is already in your car, you should flush out the coolant with DISTILLED water. Tap water is not a good idea to flush your old coolant out. Tap water has plenty of dissolved ions that just love corroding stuff, especially if stuff is made from dissimilar metals (like aluminium head + iron block). If you mix coolants, even if its 2 approved coolants, you might end up with unpredictable chemical reactions that form precipitates in the coolant, which usually get jammed up in the radiator. The problem isn't necessarily low quality coolants, this could happen from mixing 2 high quality coolants together. Coolant is not transmission fluid, just don't mix it together. As for using the wrong coolant, you have the incorrect corrosion inhibitors, which could lead to serious problems.
As for the correct concentration of coolant, this is very simple: Unless you live near or in one of the arctic circles, use 50/50. 50% is good enough down to ~-35C, and during summer, the water component can absorb around ~1.5 times more heat per mass of water than the same mass of ethylene glycol (the solvent in coolant). This is due to water's higher specific heat capacity, and if you are worried about the boiling point, remember that the cooling system must maintain pressure, as increased pressure increases the boiling point of your coolant. You should be relying on your cooling system's pressure to push back boiling point, rather than relying on the concentration of the coolant. If your system cannot maintain pressure, it is because there is a leak. Sometimes leaks can be small, so small that they won't affect your cooling system's pressure while your car is running, but you might lose a tiny bit of coolant over time. That's a different issue however.
Patman1 is offline
post #12 of 18 (permalink) Old 09-16-2016, 11:26 AM
Date registered: Jul 2005
Quoted: 1147 Post(s)
I think the chart is useful in the context that Patman describes it.
I did download it to give to my brother and some local friends.
Personally I have never had a problem diagnosing and fixing a cooling system. However I have been building race engines (both German and American) and
working on heavy agriculture equipment just for fun since I was 16.
Noodles is offline
post #13 of 18 (permalink) Old 09-16-2016, 12:21 PM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1346 Post(s)
Very easy to test.
Post it in General Stickies and close the topic.
Then we will see how many members will start topics asking additional questions.
Summer is over, so we might have to wait till spring for overheating issues to come back.
Kajtek1 is offline
post #14 of 18 (permalink) Old 09-16-2016, 12:53 PM
It was a hot summer here also. Way above average.
At the shop I am part of(more of the parts guy helping the majority owner) we saw a large increase in all sorts of cooling system failures.
Generally we only use OEm or Genuine OE parts and fluids. The customer is always an option of getting their own parts, but no warranty
if the part fails. As far as fluids only the car makers' spec or their own branded fluids are used.
Noodles is offline
post #15 of 18 (permalink) Old 09-16-2016, 05:23 PM Thread Starter
Quoted: 193 Post(s)
Well at least my chart will have the chance to get more popular, and it will be the goto chart when the next summer rolls around
Patman1 is offline
post #16 of 18 (permalink) Old 09-17-2016, 08:14 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 286 Post(s)
Nice flow chart! Here's another (a gif file) that is also generally useful in decision-making. I think it is often used in government. My Powerpoint version is animated (so better, because it unfolds progressively), but I can't post that type of file here. Enjoy!
Noodles, Kajtek1 and Deplore like this.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #17 of 18 (permalink) Old 09-17-2016, 08:54 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 447 Post(s)
Send a message via Skype™ to mrboca
This must be for those who mess with their cooling systems
mrboca is offline
post #18 of 18 (permalink) Old 09-17-2016, 10:30 AM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 476 Post(s)
Story of my life.
Noodles likes this.
--1998 MB E300TD 285k
--1997 MB E320 198k
--2004 Dodge Ram 5.7L 212k and holding (damn gas guzzler)
--2011 Suzuki DL650 44k
--1997 MB E320 161k. SOLD...loved that stupid car.
--1998 MB ML320 207k. SOLD, thank heavens!
Deplore is offline
