Rotor/Brake pad issue. HELP! - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-11-2016, 06:50 AM Thread Starter
Date registered: Aug 2016
Unhappy Rotor/Brake pad issue. HELP!
Hello. I'm new to this forum and I'm sure this question has been solved a few times but heres the issue I am having. I replaced my brakes and rotors in the front and now everytime I drive, I get a slight humming/vibration noise from in the front. When I slightly apply the brake, it goes away. During turns it gets slightly louder. I've removed and reinstalled everything back together twice now.
Again, new brakes and rotors. I purchased them at O'Reilly. Brakes are non ceramic.
Any input is appreciated.
Arthur Beshta is offline
post #2 of 6 (permalink) Old 08-11-2016, 06:52 AM Thread Starter
its a w207 2012 with 55k miles
post #3 of 6 (permalink) Old 08-11-2016, 10:35 AM
Kajtek1's Avatar
Quoted: 1163 Post(s)
Originally Posted by Arthur Beshta View Post
Again, new brakes and rotors. I purchased them at O'Reilly....
I think you draw your own conclusion.
Kajtek1 is offline
post #4 of 6 (permalink) Old 08-11-2016, 01:19 PM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160
Quoted: 473 Post(s)
You could try MB brake paste, and when that doesn't fix it try MB pads and rotors.
Your car is only 4 years old and you're already replacing original parts with those from the lowest bidder?
DrX is offline
post #5 of 6 (permalink) Old 08-11-2016, 01:34 PM
Date registered: Jul 2005
Quoted: 971 Post(s)
I am with Dr X. All of the pads' backing plats need a good high temp synthetic brake paste. Same with the sliding pins that were inside the rubber sleeves except with those the pins need to be cleaned well first.
Noodles is offline
post #6 of 6 (permalink) Old 08-12-2016, 06:50 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
Check your wheel bearings as well.
Noodles likes this.
Mike
Michael Pillay is offline
