3.2L into 260E wiring questions - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-24-2016, 04:51 AM Thread Starter
Date registered: Jul 2016
Vehicle: 1989 260E
Hello all,
A little background...
I have been on a race team with 5 other guys and we drive a 1989 260E. Recently, we decided on removing the 2.6L engine and installing a 3.2L engine from a late 1993 300CE for a bit more grunt down the straight-aways.
Here's my problem...the wiring has been a nightmare. I removed the ECM(two plug setup), E-Gas module and associated wiring harnesses from the 300CE and installed them into the 260. The E-Gas module is hooked up but there are a number of small plugs on the drivers side that I am unable to find a home for. The fuel system primes for 2 seconds when you flick the key and I get fuel pressure so i'm assuming the E-Gas computer is satisfied.
My problem is that I can't get spark or the injectors to fire. Everything seems to be satisfied from a voltage standpoint, but maybe not?? I have the wiring diagrams from this website which have been a tremendous help but i'm getting desperate as we have a race in only 2 weeks.
Questions I have...
1. What pin on the ECM (low number plug side) needs 12V?
2. What can be bypassed/grounded/tied to 12V to satisfy the ecm and allow the car to start?
I have unplugged the anti-theft computer, grounded pin 9 on the ECM an reconfigured plug "X26" on the 260 to accommodate the 300 setup.
The transmission is an automatic that's going to be shifted manually so most electronic transmission controls have been removed.
Any help would be great!
260Lemon is offline
post #2 of 3 (permalink) Old 07-24-2016, 06:50 PM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 23 Post(s)
Welcome to the forum! If you haven't already done so, I recommend posting in the 124 forums for more visibility. The guys there are extremely knowledgeable. I'd love to come out and see the car, is the next event in CT? Best of luck getting things sorted.
--Kyle
FCP Euro is offline
post #3 of 3 (permalink) Old 07-25-2016, 08:44 AM Thread Starter
Vehicle: 1989 260E
Thanks for the intro Kyle!
I found the problem last night. There is a terminal block on the drivers side fender used as a 12V junction that was mislabeled from one of my team members. It was affectionately labeled (GROUND ON DRIVERS SIDE FENDER) instead of going to 12V. I tied this connection (9 gray wires and 1 red/pink wire) to 12V and the 3.2 fired to life!
For those who are doing engine swaps, here are some words from the wise...
1) TAKE YOUR TIME labeling ALL of the connections.
2) Save the donor car until yours is running 100%
3) DON'T cut any of the wires
This was my first Mercedes swap so everything was new to me. Does anyone know what some of the high failure components are? The MAF sensor is right above the exhaust manifold...maybe I should purchase a new one just in case?
Regards
260Lemon is offline
