Could someone with a 617 manual flywheel lay it down, engine side down, then measure from top of ring gear to top of inertia ring? I've seen a picture of a 616 and 617 manual flywheel beside each other and the 300's flywheel was thicker or taller in the example above.
THANK YOU!!!
THANK YOU!!!
