I have a Mercedes OM602 engine in a Ssangyoung Korando. I want to service the injectors (fit new nozzles and replace compression springs) Does anyone have any idea of the part number of the spring? Also is the steel washer a standard size or special size?
My research tells me the part numbers are different depending on if they are Bosch or Lucas (believe the OM602 came fitted with either of these).
Mercedes spring part number for Bosch (0000171317) Bosch part number (2434619047)
Mercedes spring part number for Lucas (0000171817)
Are these part numbers correct?
Please see the diagram below
