Help with Pirelli tires on my CLK550 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-14-2015, 03:48 PM Thread Starter
Date registered: Jun 2012
Vehicle: 2009 CLK550
Hi, I put on new pirelli tires on my CLK550 9 months ago. I've only done 5.3k miles. However I see these marks on the tiers. I don't remember seeing them 15 days back. They seem to have appeared out of nowhere! Could someone please help me understand what it is? And if I need to be worried about it, or if I should change my tiers. I did leave my car with Nation Tires and Batteries in Chicago after a tire valve broke. They said due to the TPMS, they have to replace the whole valve and put a non Mercedes value and charged me $150. I don't even know if I got ripped off or not. Could they have switched my tires when I left the car with them? Here are the pics. Could it be dry rot? And can tiers dry rot in 9 months! I used it in PA mostly. And now I have it pretty much parked in KY. I noticed these marks after coming back from a trip to Chicago (Where I had taken it to NTB). Thank you for any information that can be provided.
ID:	1644385   Click image for larger version
ID:	1644393   Click image for larger version
ID:	1644401   Click image for larger version
gouthamsn is offline
post #2 of 7 (permalink) Old 10-14-2015, 06:09 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
That looks like road hazard damage to me, as in you drove over something. I rather doubt NTB would have switched out your tires, to what end?
flyboyike is offline
post #3 of 7 (permalink) Old 10-14-2015, 06:12 PM Thread Starter
Thank you for the response. Even i initially thought I probably drove over something, like bad roads or broken glass. But I don't remember doing so. But I probably might have. Could you please let me know if it's alright to drive it this way or if I need to change them?
post #4 of 7 (permalink) Old 10-15-2015, 05:05 AM
Date registered: Aug 2008
Vehicle: 2000 CLK 430 Cabriolet 2003 S500 4Matic 2004 S55 2005 CLK 500 Cabriolet 2008 S 450
Quoted: 63 Post(s)
From the pictures it doesn't look as if you have a danger type problem. I bought a Lincoln MKX for my wife that had Pirellis with like new tread. From my old tire days I remembered Pirllis as good performing tires. In my experience I think something is changed. After driving the car, off and on, for a couple of weeks I had the Pirellis removed and replaced with Michelins. The noise and hard ride was enough to make me change. I also noticed leading edge irregular wear. Just my experience but maybe something to give you to pause and reflect.
mrbobby is offline
post #5 of 7 (permalink) Old 10-15-2015, 05:35 AM Thread Starter
Thank you for the information Mr. Bobby ... These are my first Pirellis. I am happy with it either. Other than the damage (which could be my fault), I see some considerable wear, I will probably switch to Bridgestone or Continental in a few months.
post #6 of 7 (permalink) Old 10-15-2015, 08:49 AM
flyboyike's Avatar
Quoted: 68 Post(s)
I can't tell you what's alright to drive and what isn't, especially based only on a couple of photos. All I can say it looks superficial, but I haven't see the actual tire or the car, so...
post #7 of 7 (permalink) Old 10-16-2015, 06:29 AM
Quoted: 63 Post(s)
Those few square inches of rubber are all that keeps you and yours on the road side of the cemetery . If in doubt change to something that lets you feel safe.
mrbobby is offline
