Check engine light - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-14-2015, 02:07 PM Thread Starter
Date registered: Nov 2012
Check engine light
I have a 2011 C300 with 35000 miles. Recently the check engine light came on on I had it checked and reset. Then three weeks later it has come on again and the code is P0456 and it says evaporative emission system leak detection, very small leak. So not sure if it's the gas tank or not? My car is out of warranty so my question is anyone know what this may be, can I ignore it, any other ideas would be great . I'm not cheap and care for my car well, just not a great time.
Thanks
Todd
mort5029 is offline
post #2 of 4 (permalink) Old 10-14-2015, 02:09 PM
oefvetw124lover's Avatar
Date registered: Dec 2008
Vehicle: toys: 92 400e,92 300CE & 93 400SEL with daily driver:12 Civic, Workhorse: 15 F150
Quoted: 1156 Post(s)
Send a message via AIM to oefvetw124lover Send a message via Yahoo to oefvetw124lover
vaporative Emission System Leak Detected (very small leak)
What does this mean?
OBD Code P0456refers to
The Powertrain Control Module (PCM) at different times performs various tests on the EVAP system. OBD II Enhanced EVAP systems are in place to keep fuel tank vapors from venting into the atmosphere, and instead purges them into the engine to be burned. Regular pressure tests are conducted by the PCM to monitor the sealed system for leaks. The PCM monitors the EVAP system pressure by watching the fuel tank pressure (FTP) sensor. When the sensor indicates a small leak in the EVAP system, this code is set.
Symptoms
Possible symptoms of OBD code P0456
There will likely be no noticeable symptoms other than the Malfunction Indicator Lamp (MIL). This is because the EVAP system is a closed system and only controls fuel tank vapors, not engine management.
Causes
Possible causes of OBD code P0456
Usually this P0456 code is caused by an incorrect or faulty gas cap. Filling the fuel tank with the engine running could conceivable cause this code as well or if the cap wasn't properly tightened. Any of the following could also be the cause: A small leak in any of the EVAP hoses or fuel tank hoses A small leak in the purge valve or vent valve The EVAP Canister may be leaking
Possible Solutions
First, using a scan tool activate the vent solenoid, sealing the system. Then monitor the fuel tank pressure (FTP) sensor. If the system is sealing properly, the number will stay consistent. If is isn't, the pressure sensor will show that as well. If the system slowly leaks, use a smoke machine and watch for smoke exiting the system at any EVAP component. Any where there is smoke exiting the system, that is the faulty component. Do not pressurize the EVAP system with air pressure. Doing so can damage the purge and vent solenoids in the system.
Carl
Veteran
Albany, NY, USA
92 300ce and others
"Men sleep peacefully in their beds at night
because rough men stand ready
to do violence on their behalf."
Si vis pacem, para bellum
oefvetw124lover is offline
post #3 of 4 (permalink) Old 10-14-2015, 02:10 PM
start with the gas cap before you drive yourself crazy
is it OEM ? does it seal ?
Carl
Veteran
Albany, NY, USA
92 300ce and others
post #4 of 4 (permalink) Old 10-14-2015, 02:16 PM Thread Starter
Hello it's the original , should I buy a cheap after market to test then if it corrects buy a OEM.
mort5029 is offline
