Blown Head Gasket? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-31-2015, 01:31 PM Thread Starter
Date registered: Aug 2015
Blown Head Gasket?
So I did a pressure test on my 2003 c230 kompressor. The readings i got from the first 2 head was 150 and the last 2 read 180. Wondering if any one can tell me what to do next or have any tutorials on this issue.
emanislikewoah is offline
post #2 of 2 (permalink) Old 09-01-2015, 12:07 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
What procedure did you use on the test? Please be specific.
If the test isn't done properly, the results aren't valid.
Assuming your numbers are correct, you don't have a blown head gasket, but there are other issues.
Good luck.
Check Codes is offline
