The most worrying ticking sound ever - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-28-2015, 04:06 AM Thread Starter
Date registered: May 2015
Vehicle: 2005 C220
Purely for amusement, yet it may have value for fellow members.
My C220 developed a ticking noise which was speed related, not showing until I reached 20mph, then the faster I went, the quicker the beat. The noise came from beneath the vehicle, yet the sound deadening is so effective, I wondered if it was a wheel, something on the brakes or suspension. Investigating time and again, nothing was found, yet the sound now pin-pointed to the back of the gearbox. Fear of a massive bill was setting in Could it be the output bearing on the prop, maybe a UJ clicking away, still nothing after further inspection, the tension gathered momentum.
After getting the vehicle up on a ramp and removing the aluminium heat shield to 'again' expose the prop, I had the car in drive to spin the wheels! The culprit was identified at last. The bar code decal on the prop had half unstuck itself, the centrifugal thrust of the prop lifted half the decal from its adhered position where it would thrash against the cars underside, yet as the vehicle road speed reduced, the decal returned to its moulded form and looked normal.
I merely pulled the decal off, the problem went instantly. Worry about the worst, and the least happens!
Check Codes likes this.
All the gear with no idea is offline
post #2 of 2 (permalink) Old 05-28-2015, 08:53 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Good to hear such easy fixes.
Years ago my father paid pretty hefty bill for removing few rocks from driveshaft tunnel.
Kajtek1 is offline
