balance shaft failure - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-10-2015, 10:45 PM Thread Starter
Date registered: Dec 2014
Vehicle: 2014 Glk350, 2015 ML250
Quoted: 2 Post(s)
Someone please advise is the 2005 SLK350 included in the bad balance shaft engines?
As I remember it was most V6 from 2006 thru mid 2008. But the 2005 SLK350 used the new 350 engine while other 2005 for example had the 320 engine which was OK.I am looking at a 2005 SLK350 with 100K miles and don't want to make a mistake
Thanks. New to this site so hope I am in the right forum?
ricky is offline
post #2 of 3 (permalink) Old 03-10-2015, 11:09 PM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 877 Post(s)
Have the seller provide the VIN and check with a dealer to see if it is an affected engine number.
If it is and has gone this far it probably wont fail. Only a percentage of the M272 V6 350 engines failed. Or a dealer might say this one was repaired with new parts.
Noodles is offline
post #3 of 3 (permalink) Old 03-12-2015, 07:29 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
Run a VMI so we can see the engine number and check it with these number below. Let me know if you have any questions.
Engine 272 in model 164, 171, 203, 209, 211, 219, 221, 230, 251
Engine 273 in model 164, 209, 211, 216, 219, 221, 230
Implementation of series measure changing material for balance shaft sprocket as of engine 2729xx30 468993 as of October 2006 production
Implementation of series measure changing material for timing chain guide wheel as of engine 2739xx30 088611 as of September 2006 production
saleen1276 is offline
