MFD is hard to read when weather is warm - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-22-2015, 01:54 PM Thread Starter
Date registered: Dec 2014
Vehicle: 2006 E500 Sadan 120k and 2005 C240 4matic 103k
Quoted: 10 Post(s)
Why does the MFD becomes hard to read when the outside temperature reaches 70F. Mostly the top and bottom lines of the display get vague and difficult to read. Is the display going bad? There are no codes other than left signal light malfunction which I need to replace the multifunction switch.
Alexqkama is offline
post #2 of 2 (permalink) Old 02-22-2015, 04:17 PM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 877 Post(s)
In most cases when that happens the display is on its way out. The gauge cluster can be removed and checked by an electronics specialist. It may just need some solder joints patched, but at close to 12 years old it may be past the point of fixing and need replacing.
Noodles is offline
