coolant leak - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-08-2015, 04:15 PM Thread Starter
Date registered: Jan 2015
Exclamation coolant leak
can you use a sealant on the radiator for a 2001 clk 55
55rider is offline
post #2 of 2 (permalink) Old 01-08-2015, 04:44 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
I would not.
For one, sealants go everywhere and can cause problems. (In a beater, perhaps.)
For two, the sealant won't work if the leak is at the tank joint as it is a composite.
The radiators are really not that expensive, so just replace it.
Check Codes is offline
