Can I put a tow bar on a 1998 Mercedes Ml320 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-02-2015, 01:53 PM Thread Starter
Date registered: Dec 2014
Quoted: 2 Post(s)
I will be towing my 1998 Mercedes Ml320, and I just bought an attachable tow bar that's supposed to be bolted to the truck, and then pulled by a hitch. Are there spots on the undercarriage where this bar can be bolted?
Also, I guess I have to unhook the drive shaft, in order to tow it. Does anyone have any advice or information about this?
Thank you!
bigbenz1910 is offline
post #2 of 5 (permalink) Old 01-02-2015, 11:56 PM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 877 Post(s)
We went through a thread with you about this in the W163 forum.
You can not tow with that AWD system unless you use a dolly trailer and like you said unhook the drives shaft. If you want to tow it with all four wheels on the ground you will have to unhook the front and rear drive shafts.
The mounting location of the tow bar will depend on the manufacturer's instructions.
Noodles is offline
post #3 of 5 (permalink) Old 01-03-2015, 07:14 AM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 200 Post(s)
Maybe if you keep asking the question, you'll eventually get an answer you want to hear. Go ahead and tow it. You will regret it.
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #4 of 5 (permalink) Old 01-03-2015, 07:22 AM
oefvetw124lover's Avatar
Date registered: Dec 2008
Vehicle: toys: 92 400e,92 300CE & 93 400SEL with daily driver:12 Civic, Workhorse: 15 F150 & Porsche 944
Quoted: 1047 Post(s)
Send a message via AIM to oefvetw124lover Send a message via Yahoo to oefvetw124lover
I did the research on this topic AND I'm not a W163 owner (although, at one point I was contemplating the purchase of a ML 500)
Albany, NY, USA
92 300ce and others
"Men sleep peacefully in their beds at night
because rough men stand ready
to do violence on their behalf."
Si vis pacem, para bellum
oefvetw124lover is offline
post #5 of 5 (permalink) Old 01-03-2015, 08:44 AM
Kajtek1's Avatar
Quoted: 1058 Post(s)
Just to make it clear W163 has 2 driveshafts to disconnect.
I was considering using ML as toad years ago and my final conclusion was build a light trailer, similar to those Uhaul is using.
Standard car haulers are too big
Never did it as dirt bike carried on motorhome was all I needed.
Kajtek1 is online now
