Engine\trans swap 80' 240d to 83' 300d - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-10-2014, 11:08 AM Thread Starter
Date registered: May 2014
Vehicle: 1980 240d
Exclamation Engine\trans swap 80' 240d to 83' 300d
Got a chance to pick up a 1983 300d excellent body and interior-no engine transmission. Can I put my 240d engine and transmission into it????
Without too much modification? thanks!
fourtyres is offline
post #2 of 2 (permalink) Old 09-10-2014, 04:05 PM
Kajtek1's Avatar
Quoted: 1191 Post(s)
You don't have computers that on newer engines have to be swapped as well, so that is very good news.
Since both engines come from the same body, I would believe the job suppose to be on easy side. With good luck even motor mounts and driveshaft might fit.
I would worry about differential ratio. Very likely they had it different, but that means your 240 will have overdrive, what is better than having under-drive.
Good luck, no matter what you decide.
Kajtek1 is offline
