Mercedes A170 Gearbox - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-29-2014, 01:44 PM Thread Starter
Date registered: Apr 2014
Vehicle: 2002 Mercedes E220 CDI
Hello Guys
I am Dinos, I am new to the forum. I have a Mercedes A170
I have problem with the gearbox i think. The car wont move or reverse as it should.
I need to press the gas slowly slowly until it start moving (take about 12-15 seconds).
If i press the petal too fast then it start moving but it is kinda confused, it accelerates very fast and shakes.
Anyway i put it on a Diagnosis machine an got the following errors:
I get the following error codes:Petrol (266.940 - SIM266 - MT/AT - 169.032/332)
DTC Description
00C9 - Fault is stored in automatic transmission control unit: Transmission Fluid
Pressure Sensor/Switch A Circuit Range/Performance
- Intermittent
Brake (ESP (Electronic Stability Program) - ESP169 (Electronic Stability
Program) - MT/AT)
DTC Description
6319 - CAN: communication engine
- IntermittentInstrument (Instrument - Instrument - MT/AT)
DTC Description
9141 - Temperature sensor
- IntermittentGearbox (Gearbox - FCVT (CVT gearbox; (Continuously variable automatic
transmission)) - AT)
DTC Description
2732 - Hydraulic brake 'forward gear'; impermissible opening
- Permanent
0841 - While driving, the actual hydraulic pressure is implausible in comparison with
the specified hydraulic pressure in transmission
- PermanentMultifunction (Roof contr. - RCM (Roof control module) - MT/AT)
DTC Description
9001 - The supply voltage of the control unit is too low (undervoltage).
kkdigger is offline
