Strange Clicking Sound in the Cooling/Heating System - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-20-2014, 04:44 PM Thread Starter
addguy111's Avatar
Date registered: Aug 2007
Vehicle: 2007 SLK 280
Sort of hard to explain this problem, but here goes. We have a 2003 C240 AWD. When the car is started, for the first 15-20 seconds there is a series of clicking sounds - always 5-7 instances, then they stops. The sound sounds similar to the auto locks on the doors locking. But it comes from the a/c vents in the dash. The a/c fan also seems to stop blowing cold air as each "sound" occurs then rises quickly back up to normal levels before falling at the next "click". It only happens at start, then everything runs normally for the duration of the trip. About two months ago we did have to replace the condenser in order to get cold air blowing. Seems unrelated to that, but maybe. Any ideas?
addguy111 is offline
post #2 of 2 (permalink) Old 07-21-2014, 12:03 AM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 121 Post(s)
This is normally a broken flap in the heater box, there is a re set that you could try
To reset heater flaps and actuators
Switch on ignition.
Press recirculated air and defrost buttons on control panel together for longer than 5 seconds.
The LED's in the defrost and recirculated air buttons flash alternately.
Wait until the LED's stop flashing (approx 30 sec) system set to defrost LED on.
Switch off ignition.
After 40 sec re start engine.
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
