Smart Key wont turn and no power to vehicle - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-08-2014, 03:11 PM Thread Starter
Miss_Mal's Avatar
Date registered: Nov 2013
Vehicle: 1999 C230 Kompressor Blk on Blk
Hi There,
I have a 1999 C230 Kompressor. A couple days ago I drove and then parked my car. A day later I went to drive the car again but the smart key physically will not turn positions in the ignition.
The car does not appear to have any power. The dome, break, emergency lights dont come on. The seat belt and open door warning does not go off.
The day before this happened the car alarm went off for seemingly no reason. A few days prior I noticed that when I used to remote to lock the car doors the head lights did not flash showing the car was responding to the remote. I am not certain but I still think the remote was locking the door.
We want to be able to at least pull out the battery but we cant even do that. I have not been able to open the trunk with it.
Thank you in advance for any insight you may have!
Miss_Mal is offline
post #2 of 3 (permalink) Old 07-08-2014, 09:14 PM
Kajtek1's Avatar
Quoted: 1068 Post(s)
I drive E class, but Mercedes usually install mechanical lock on trunk as well.
It is quite common that the mechanism - not used for years will freeze, but several sprays of WD40 inside and exercising usually will make the tumbler turn.
Go to your model section for more direct experience.
Miss_Mal likes this.
Kajtek1 is online now
post #3 of 3 (permalink) Old 07-08-2014, 10:11 PM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 121 Post(s)
You have a plastic cover ½ way along the fender on the inside under the hood, lift that panel and you will see a charging connection, just hook a charger up to it and the remote will function again to release the trunk.
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
