How much is a replacement Mercedes Benz key fob at the dealer? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-23-2014, 04:49 PM Thread Starter
Date registered: Jun 2014
Vehicle: 2011 Mercedes Benz C300
Did any of you ever needed to get a new Mercedes Benz key fob? How much did you pay? Where did you get it? How long did it take to get it?
c300_kacper is offline
post #2 of 9 (permalink) Old 06-23-2014, 09:11 PM
Kajtek1's Avatar
Quoted: 1197 Post(s)
$180 retail. Some dealers will give you discount, some markup.
Ships overnight from Texas.
Kajtek1 is offline
post #3 of 9 (permalink) Old 06-23-2014, 11:54 PM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 148 Post(s)
The standard chrome replacement keys in the UK cost £225.
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #4 of 9 (permalink) Old 06-28-2014, 10:22 PM
Vehicle: 2000 SL 500
Quoted: 2 Post(s)
Picked up a new key fob and a valet key as well. was in no rush so picked it up about 3 days later. $274.00 US at MB dealer in Wilmington, DE. They did of course then have to code it to the car which took only minutes to do. After I saw the price, I figured there was probably a less expensive way but you live & learn.
rickealloway is offline
post #5 of 9 (permalink) Old 06-29-2014, 12:16 AM
television's Avatar
Quoted: 148 Post(s)
A 129 does not require coding, just press any button twice and insert in ignition within 4 seconds, one car re set this way as well.
Malcolm
post #6 of 9 (permalink) Old 06-29-2014, 01:33 AM
television's Avatar
Quoted: 148 Post(s)
Originally Posted by Noodles View Post
Over here they will start the car, but to use the keyless entry they have to be programmed into an available slot in the EAM. (Or so the MB dealers have led people to believe.)
I have never tried with cars older than 2000, to set the keyless go part, you just place both keys in the car, go to the key setting on STAR, just press activate and about 2 mins later its either job done or no keys found. I have never seen a new entry for doing this part of the key.
Malcolm
post #7 of 9 (permalink) Old 06-29-2014, 03:12 AM
Date registered: Jul 2005
Quoted: 1016 Post(s)
I forgot the 2000 SL 500s had keyless go as an option.
I am deleting my previous post to avoid any confusion.
Noodles is offline
post #8 of 9 (permalink) Old 06-29-2014, 08:29 PM
Quoted: 2 Post(s)
Can only tell you a couple of people in the parts Dept. had an open conversation about what to do with the new key fob to "get it set up" for the car. Following a few minutes on the computer, the gentleman came out to my car, pointed the fob at the car & clicked a button or 2 & then got it right into the ignition. If it was a show it looked good to me.
I can tell you the key fob has worked okay since then.
post #9 of 9 (permalink) Old 06-29-2014, 09:56 PM
Kajtek1's Avatar
That was likely new key, that was programmed for new space on car computer back in Texas.
The replacement keys require hooking up to SD to delete lost key and reprogram the new one into the place.
Kajtek1 is offline
