exhaust question ml320 2000 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-02-2014, 08:40 PM Thread Starter
Date registered: Sep 2010
Vehicle: ml320 2000 240,000
Smile exhaust question ml320 2000
a rattling noise has started inside the resonator. It only happens when it is idling in drive. the object in question is on the left side of the exhaust system. there is the catalytic convertor then the resonator than another muffler like compartment than it connects to the muffler. The other muffler like compartment is where the rattling is occurring. The dealer tells me its all one part. Is there a safety issue if I don't repair this right away. The noise is annoying but the cost is also a bit more annoying at this time. ml320 2000 200,000 miles.
mannyo is online now
post #2 of 8 (permalink) Old 06-02-2014, 11:04 PM
Date registered: Jul 2005
Quoted: 976 Post(s)
I believe your are talking about the second cat. There are 2 on each side.
Please tell us which number on this diagram you are referring to.
Noodles is offline
post #3 of 8 (permalink) Old 06-02-2014, 11:46 PM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160
Quoted: 474 Post(s)
Originally Posted by mannyo View Post
there is the catalytic convertor then the resonator than another muffler like compartment than it connects to the muffler. The other muffler like compartment is where the rattling is occurring. ... Is there a safety issue if I don't repair this right away. The noise is annoying but the cost is also a bit more annoying at this time.
The 2nd bulge is another catalytic converter. Part of the ceramic honeycomb of the converter has broken off and is rattling around. When exhaust pressure increases, that fragment is trapped by the airflow.
It's not a safety issue and won't cause increased damage if you put up with it. You can buy a remanufactured cat cheaper than a new one. Works the same. --> CATALYST. REMANUFACTURED. EXHAUST SYSTEM USED ON SIX-CYLINDER GASOLINE VEHICLES. 2000 Mercedes ML 320 # 163490971488
DrX is offline
post #4 of 8 (permalink) Old 06-03-2014, 06:12 AM Thread Starter
On the diagram its number 5, the third part after the exhaust manifold. Is it another catalytic converter?
post #5 of 8 (permalink) Old 06-03-2014, 12:20 PM
Quoted: 976 Post(s)
That is the catalytic pipe which contains both the upstream and downstream cats. It is usually sold as one whole pipe. The price is alarming. Seeing as you are not in California you can get an aftermarket one for $1000 less than one from MB.
Noodles is offline
post #6 of 8 (permalink) Old 06-03-2014, 05:55 PM
DrX
DrX's Avatar
Quoted: 474 Post(s)
The remanufactured cat for your MY2000 is only $420 full RRP. The catalyst is made of rare earth minerals which don't come cheap.
I see that part #5 has 2 bulges which contain the catalyst, then a 3rd section which is where the rattle is. The 3rd section is not another cat, but it has caught the fragment from the 2nd cat. Doesn't matter anyway as you need to replace the whole assembly.
DrX is offline
post #7 of 8 (permalink) Old 06-18-2014, 11:01 AM Thread Starter
how difficult is it to remove the torsion bar? Special instructions on replacing the torsion bar.
post #8 of 8 (permalink) Old 06-18-2014, 12:19 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
http://www.benzworld.org/forums/w163...converter.html
Mike
Michael Pillay is offline
