Airmatic problem no power, searched for days... NEED HELP - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-28-2014, 05:32 PM Thread Starter
Date registered: May 2014
Vehicle: 2006 Cls500
Ok first off im not a certified mechanic but i do know my way around cars,i do all mine and my friends work.(done engine swaps,turbo install,suspension, etc) Ok so im working on a 2006 CLS500 with airmatic his rear right air spring was blown(shop diagnosed it) after some research we decided to replace both rears with arnott and the compressor and relay. Everything is installed but the compressor relay is not getting a signal to turn on. If i jump the wires at the relay i can get the compressor to run but it wont turn on by itself. I also have air at all corners but i believe the valve on the air spring is not opening to let air in. I dont believe i have a leak because the air at the springs stays there unless i loosen the fitting. The rear is all the way down so it would need to be towed to the nearest dealer to me which is 30mins awaywhich is why im asking here before i spend anymore money. Any one have this problem or know what it could be?? Any help is appreciated....
Things Checked
-Compressor Runs when wire jumped
-New Relay
-Tested all fuses in the car
-Air in system and getting to all springs
dek1mfk is offline
post #2 of 3 (permalink) Old 05-28-2014, 06:35 PM
Ex-Fed's Avatar
Date registered: May 2013
Vehicle: 2006 S 500
Quoted: 116 Post(s)
If the compressor was shut down with the self protection mechanism, I believe you will have to have the trouble codes cleared ( with STAR ) before it will power back up.
Ex-Fed is offline
post #3 of 3 (permalink) Old 05-29-2014, 12:32 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Seems that even tire inflating on 2003 and younger MB require Star Diagnosis.
Earlier on S class.
Kajtek1 is online now
