Can I use all water instead of 50/50 coolant? - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 05-20-2014, 11:11 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
It's your car, you can do anything you like with it. Heck, try used motor oil, it's cheaper. Maybe cooking oil will work well as brake fluid and ATF.
Seriously, the issue is trying to find a workaround for something instead of just fixing the leak. If you continue to ignore it, then you're going to be back posting to see if you can use cardboard to replace your head gasket.
Good luck.
Check Codes is offline
post #12 of 16 (permalink) Old 05-21-2014, 07:59 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Living in communism we did not have coolants available, so lot of cars drove on water. It was annoying in winter, when you had to drain it for every stop longer than 2 hr.
Couple of my friends pour diesel in cooling system to avoid the hassle.
That was in cold climate so perfect heat exchange was not important and cars did not last long, so long lasting radiators were not important.
So regardless how badly some MB owners feel about violating the rules, water will not kill the car, but use distillate water as tap water will deposit boiling stone.
Another myth is coolant poisoning. Years ago my friend work on my yard at his car and had coolant in pan on the ground. 2 neighbor dogs jumped the fence and drunk most of it. Later on neighbor gave one of the dog to us and she lived happily till 16, what is good age for German Sheppard.
Kajtek1 is offline
post #13 of 16 (permalink) Old 05-26-2014, 06:03 AM
Date registered: May 2014
Vehicle: 2002
yeah, i guess so! but go for coolant !
andrewwales is offline
post #14 of 16 (permalink) Old 05-27-2014, 07:40 AM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 152 Post(s)
for Kaitjek
I usually agree with you most of the time but I must disagree irt anti-freeze poisoning. I lost my most favorite ex-dog to it. You could see the green tinge around his mouth where he had been vomiting. The mechanism is crystalization in the kidneys, leading to failure.
Perhaps in your case the anti-freeze was other than ethylene glycol. There are many compounds for use in things like solar water applications and for use by environmentally sensitive tree-huggers that use a non-toxic mix, usually propylene glycol.
rocky raccoon is offline
post #15 of 16 (permalink) Old 05-27-2014, 08:14 AM
Kajtek1's Avatar
Obviously I should add "Don't try it at home" to my previous post
The incident with dogs drinking coolant happened like 20 years ago and I don't know what coolant it was. In my days when I work more on cars, I had lot of times when I was sucking coolants, gasoline, diesel with my mouth and never had any poisoning.
Obviously I did not swallow it, but spit out.
Add to that that in my younger years I was cutting asbestos with hacksaw, was playing with mercury on my skin just because it was fun and inhale some of Chernobyl radiation from 300 miles away
Hard to kill Polish
Kajtek1 is offline
post #16 of 16 (permalink) Old 05-28-2014, 01:31 PM
Cinnasnootzer's Avatar
Date registered: Mar 2014
Vehicle: 2001 ML320 2004 ML500 2011 E350 2015 ML350 2002 CL55 AMG
Quoted: 181 Post(s)
The cooling system is designed to "never need servicing" and is sealed for life with superspecial Uber sauce.
"Can we fill it with hydraulic fluid? " -MB Engineer.
Cinnasnootzer is offline
