Oil level? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-01-2014, 05:22 PM Thread Starter
Date registered: Apr 2014
Vehicle: 1999 E320 4Matic Wagon
Quoted: 2 Post(s)
Oil level?
E320 4matic wagon. Oil level is a tad above the full mark on the dip stick. Owners manual makes it seem that this is really bad. Is it?
Ducati-Guy is offline
post #2 of 3 (permalink) Old 05-01-2014, 07:35 PM
Date registered: Nov 2003
Vehicle: 2004 CLK320
Quoted: 5 Post(s)
If you are measuring the oil level when the engine is hot, a tad above the max should be fine.
Otherwise if the engine is cold, you better remove some oil. Too much oil will damage the engine. Google it.
Check Codes likes this.
mis3 is offline
post #3 of 3 (permalink) Old 05-01-2014, 07:55 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Check it through the MFD. If that says it's okay, then relax.
BTW, you have a W210 and you are better off asking specific questions about your car in that forum. This general one is about all Mercedes...
Good luck.
Check Codes is offline
