dual flywheel (maybe not Mercedes) - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-15-2014, 02:34 AM Thread Starter
Date registered: Jan 2011
I hear a grinding noise when I press the clutch pedal.
I think the dual flywheel is getting out of order ( the car is a Peugeot 407HDI 2.0 liters).
I was told that a solution could be to weld the two flywheel masses. What do you think?
If welded would it create later more serious problems on the engine/ gear box?
Did someone have any experience and already done it?
Could he post some information, or to tell me where welding spots have to be, any pictures would be useful?
Thank you in advance for your advice
cc260Ebis is offline
post #2 of 2 (permalink) Old 03-15-2014, 11:48 AM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 877 Post(s)
It could also be the throwout bearing. If the dual flywheel is out of sync then you can get a used one or a new one. Welding it together is not the best the fix.
Noodles is offline
