1982 240d will not run when put in drive - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-06-2014, 02:04 PM Thread Starter
Date registered: Apr 2010
Had to get mechanic to swap out injector pump on 1982 240d 4 cylinder. car will crank up and run but cuts off when put in drive,he can not figure out what is going on. Any help or advice would be appreciated. Thanks! tcb2
tcb2 is offline
post #2 of 2 (permalink) Old 03-06-2014, 04:46 PM
Date registered: Jul 2005
Quoted: 1058 Post(s)
Air in the system or the pump from the tank is weak and needs replacing. Which means you may not have needed the injector pump unless it was leaking.
Noodles is offline
