2009 GL 320 starter! Need help! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-01-2014, 10:55 AM Thread Starter
Date registered: Mar 2014
Vehicle: 2009 GL320 Bluetec
I own a 2009 GL 320 bluetec with 90,000km on it. The car is dealer maintained and is a pleasure to drive. I live in a city where the temperatures can fall below -30. My question is that, why doesn't the car start when the key is turned even after letting the glow plugs heat?
I start the car, it tries to turn then I have to turn the key back to normal position and pull it out of the ignition. Then when I keep the key in start position it fires 3 times till it starts on the 4th one!
The dealership changed the battery and fixed some connection issues, but the problem still persists. Regardless of -30, the car behaves in the same manner even when it is -10 out.
Does anyone know about this?
ms1130 is offline
post #2 of 2 (permalink) Old 03-02-2014, 09:37 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Can you clarify the "fires three times, starts on the fourth try" statement?
flyboyike is offline
