WILL THESE RIMS & TIRES FIT MY 2001 C240? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-24-2014, 09:28 PM Thread Starter
Date registered: Feb 2014
Vehicle: 2001 C240
OEM Mercedes AMG wheels from a CLS55.
Front Wheel Size:18" x 8.5" 25mm offset
Rear Wheel Size:18" x 9.5" 28mm offset
Bolt Pattern: 5x112
Pirelli tires
front tires 255/40/18 50% left
rear tires 285/35/18 90% left
I currently have 19" iForged Daytonas but the ride is too rough, would these give me a smoother ride? Thanks for the advice!!
SanJo240 is offline
post #2 of 3 (permalink) Old 02-24-2014, 10:49 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Not even close, my friend.
Too wide, wrong offset, tires are far too large.
Best to get your info from the 203 forum rather than the general one.
Good luck.
Check Codes is offline
post #3 of 3 (permalink) Old 07-14-2015, 11:48 AM
UPWheels's Avatar
Date registered: Jun 2015
Agree with Codes. Offset is too aggressive and will potentially stick out past your fender, causing tire rubbing. We've test fit 19x8.5 and 19x9.5 with a +35 offset, and they fit fine as long as the correct tire sizes are used. Optimal offset would be +35 for front and rears. Good luck on your search.
UPWheels is offline
