1995 SL 320 Check Engine Light - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-20-2014, 02:54 PM Thread Starter
PJ's SL 320's Avatar
Date registered: Feb 2014
Vehicle: 1995 SL 320
HELP! I have only had my car for a few months, but can't seem to keep the Check Engine light out for more than a few hundred miles at a time after resetting at the shop. The only thing the engine does, at times, is start hard when hot (turns over quite a bit before firing, and then can smell gas). All other times everything is normal. So far the codes and fixes have not helped.
PJ's SL 320 is offline
post #2 of 4 (permalink) Old 02-20-2014, 03:00 PM
Date registered: Jul 2005
Quoted: 1008 Post(s)
What are the codes and what have you tried fixing/replacing?
Noodles is offline
post #3 of 4 (permalink) Old 02-20-2014, 05:02 PM Thread Starter
My shop has cleaned an EGR pipe but it keeps coming back with that code, don't know the number myself. They say the system that is coding is OK, so now they think it might be the code sensor itself. But the hard warm starting? Don't see how a bad sensor could cause that.
Also, the shop did replace a $170 valve that purges the fuel tank? That was no help.
post #4 of 4 (permalink) Old 02-20-2014, 07:07 PM
Kajtek1's Avatar
Quoted: 1191 Post(s)
You have first generation of computerized engine management and the sensors from 1990's don't have good reliability records.
Still you should find qualified mechanic who can deal with it.
Without the codes, all we can do is to give you moral support.
Kajtek1 is online now
