blower resistor no bus communication code 9360 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-19-2014, 03:38 PM Thread Starter
Date registered: Feb 2014
Vehicle: 07 cls550
Exclamation blower resistor no bus communication code 9360
hello, im bryan.
new to forums as of today. i have just finished replaceing an evaporator core on a 07 cls550. after putting it all back together the blower is innoperable w/ a/c code :
9360 (communication error of ac bus with component a32n1 blower regulator).
any quick advise on trouble shooting would be awesome. fyi already tried new resistor and tore dash down 4 times to ensure all connections are correct and intact.
barbiea121 is offline
post #2 of 4 (permalink) Old 02-20-2014, 09:19 AM Thread Starter
Vehicle: 07 cls550
no one?
post #3 of 4 (permalink) Old 02-20-2014, 01:53 PM
Date registered: Jul 2005
Quoted: 973 Post(s)
The only thing I can suggest at this point would be to find a shop with the MB star system and have the system scanned for codes. At least that would narrow it down to the part/module that is causing the fault.
Noodles is offline
post #4 of 4 (permalink) Old 02-21-2014, 11:15 AM
Ex-Fed's Avatar
Date registered: May 2013
Vehicle: 2006 S 500
Quoted: 116 Post(s)
Just brainstorming....
There being just the one connector to blower controller (A32n1), voltage, ground and LIN ( Local Interconnect Network )... and noting that your tried a second A32n1 module, very slim chance both are bad. But it could happen.
Check the plug and the connector for bent/misaligned pins, especially for the Blue/Green wire ( LIN connection). If all is well you may need to get to the back of the center console control unit and see if the connection to it is secure with all the pins where they are supposed to be etc. Physical integrity of the LIN wire is next I guess. Having to pretty much remove the entire dash assembly for the core replacement, wire may have been cut somewhere.
May have to have all the codes cleared. There are reset procedures for the C, E and S class but cant find anything specific for the 07 CLS. STAR may be your only answer at that point.
Ex-Fed is offline
