Valve stem seal replacement help please!! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-18-2014, 08:45 PM Thread Starter
Date registered: Nov 2013
Vehicle: 2000 c230 kompressor
Hey I have a 2000 Mercedes c230 kompressor and I have to change the valve stem seals because the spark plug well and the spark plugs themselves are flooded with oil. If anyone knows how to switch the valve cover gasket plus the valve stem seals I'd need some help.
If anyone has switched theirs already or just knows how to do it could you help me.
please and thank you in advance.
mercedesw202 is offline
post #2 of 3 (permalink) Old 01-19-2014, 04:07 AM
Date registered: Aug 2008
Vehicle: 2000 CLK 430 Cabriolet 2003 S500 4Matic 2004 S55 2005 CLK 500 Cabriolet 2008 S 450
Quoted: 63 Post(s)
I'm a little confused with your question . If we call the well that the spark plug sits in as part of the exterior side of the head then the valve seals are not part of the problem. A picture or more concise explanation may elicit more responses for you.
mrbobby is offline
post #3 of 3 (permalink) Old 01-19-2014, 05:49 AM
nathanD.rector's Avatar
Date registered: Jan 2013
Vehicle: 99 s320,and 83 300sd
Quoted: 217 Post(s)
if you plug fit down in a hole in the valve cover,then the rubber seals around the plug are bad.They are known to get dry and fail.
1999 s320. and 83 300sd quit driving,people make me nervous
nathanD.rector is offline
