Unique Problem Now That It Is Cold Here in GA - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-08-2014, 06:01 AM Thread Starter
Date registered: Apr 2007
I go to the car, a 2004 Mercedes C240 4Matic, and use the unlock button on my fob. Works fine.
Put the key fob in the ignition. The car lights up with the odometer showing the miles and the park key on the red dot.
Turn the key to the on position and the dash lights up.
I twist to start it up and... nothing.
The dashboard instrument display stays on. It's almost as if the car is acknowledging the key in the ignition. But not the key actually turning to start up the vehicle.
Any help with this would be most welcome. Thanks, and I hope you have a warm week ahead.
macarose is offline
post #2 of 8 (permalink) Old 01-08-2014, 06:12 AM
JN74SL's Avatar
Date registered: Apr 2013
Vehicle: Monika '74 450SL and her lil sis BrownHilda '79 280SL
Quoted: 215 Post(s)
Weak battery?
How bright are the headlights?
The cold can kill a battery pretty quickly
Current:
Reggie 2010 Range Rover Sport Supercharged
Monika '74 450 SL
BrownHilda '79 280 SL ex-Zender
Scarlett 2014 Jeep Cherokee 4wd
FoxyCleopatra '99 Chevy Suburban
Krystal 2004 Volvo S60
Gone:
Rudolf ‘86 300SDL
Bruno '81 300SD
Fritzi '84 BMW
'06 Volvo S60 AWD turbo
'97 Jeep GC
'96 Volvo 960
'96 Impala SS
'92 Subaru Legacy wagon
'74 Jeep CJ5
'71 Buick GS conv
'67 GTO conv
'63 Corvair conv
'57 Nomad
JN74SL is offline
post #3 of 8 (permalink) Old 01-08-2014, 06:39 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
You twist the key but nothing happens, does it mean the key does not turn in the ignition slot at all?
Do you have a spare key, does it behave the same way?
Depending on the actual key behaviour it could be a broken key (most often the coil that picks up power from the ignition slot loosing solder contact to the circuit board, or broken coil, you can try to press the "open door locks" button and then immediately try to turn the key), it could be the ignition slot (EIS), the electronic steering lock or if the key actually turns it could be the starter relay, the starter solenoid or the starter itself, or a starter fuse or...
Diesel Benz is offline
post #4 of 8 (permalink) Old 01-08-2014, 06:41 AM Thread Starter
It does turn. The dash stays the same as if the car is not reading the fob. All the doors open and lock and the alarm works as well. I may just use a battery and see if that helps the cause.
macarose is offline
post #5 of 8 (permalink) Old 01-08-2014, 06:53 AM
Quoted: 39 Post(s)
The key should be fine then. You could measure the battery voltage but it is probably something different. On a 203 the fuse for the starter battery may blow if the starter is at end of life. Check from the starter relay if it has voltage and if it has, check the starter solenoid signal pin, check ground wires too.
If you listen carefully, can you hear the small starter relay engage at the fuse box (not the big starter solenoid)?
post #6 of 8 (permalink) Old 01-08-2014, 07:13 AM Thread Starter
Gonna do that right now. Thanks!
macarose is offline
post #7 of 8 (permalink) Old 01-08-2014, 07:21 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 399 Post(s)
(Some of my reply has been already said above, while I was drafting this post - however I have left it in.)
From your report, quite a lot is working OK. (assuming that the battery is up to scratch, as suggested above) You also mean that the car is not Cranking, I assume? Starting is when the engine runs.
1. Ignition key turns from posn 0 to posn 'Start' means that the key is OK, ignition switch is OK, steering lock is OK, DAS is OK (drive authorization system)
2. That means that you have 'permission to start'.
Turning the switch to the Start position should energise the Starter relay (N10/1 kS) located in the engine bay, which in turn will energise the Starter solenoid, located on the starter unit. You should be able to hear both relays click when the key is turned to Start.
If no 'click', try replacing the Starter relay. I would remove the relay case and inspect the contacts inside. For an emergency you can burnish damaged contacts with fine emery paper, just to get yourself moving again.
Other possibilities.
3. There is also a fuse 52 (15A) in the starter (M4) circuit. Check that out.
4. The starter could be toast - or maybe it has jammed and blown fuse 52. Sometimes a smart blow to the case with a mallet can free it up! If all else is OK, try that...
keyhole is online now
post #8 of 8 (permalink) Old 01-08-2014, 09:48 AM
Date registered: Mar 2012
Vehicle: 2010 B200
Quoted: 13 Post(s)
with the wind chill warning of -30 to -40F, I left my battery charger on overnight, trickle charge/tender charge and it starts fine. Battery was at 35-45% at 0F so charging battery to 100% helps everything
oyster is offline
