E320 211 seat draining battery help - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-25-2013, 06:04 AM Thread Starter
Date registered: Dec 2013
Vehicle: 2003 E320 211
Red face E320 211 seat draining battery help
2003 E320 4 door
Short story is: there is a 2.2 amp drain on my battery when fuse 34 is in place & when the network should be asleep. If I pull fuse 34 I have 80 ma draw and no driver seat action.
I would like to avoid the dealership and I have no present ability to scan. I would like to see if I can solve this by process of elimination and logic. If not I will by a Benz scanner$$$$ but first I must try. I can diagnose and solve electrical problems, I do it for a living in the form of building HVAC controls. I have moved from a W126 to this W211 and have no previous experience with this car so please help.
I suspect that the controller to the driver's seat's motors is the drain or something is goofed with it. I have found that if I pull CAN out of the module the un-wanted draw will go away in about 4 Min
1 Can you tell me exactly how to remove this module? I am too old to get under the seat more then twice a day it takes too much Advil.
2 Is the passenger seat adjustment controller the same? PNs are different but can controllers be swapped? If so I plan to swap parts to see if it is the controller or a network issue? Will the drivers side controller react in the passenger position from the drivers hand control? I can prove the issue if this can be done. If not I will just figure out how to analyze it some other way.
3 Is there any concern about driving this car with the f34 fuse pulled? I am afraid it could supply Volt source to other points then just this seat.
4 Any other ideas could help?
Thanks in advance for any help or smart cracks given, Bruce
Last edited by brujan; 12-25-2013 at 09:14 AM. Reason: new information discovered (up date)
brujan is offline
post #2 of 2 (permalink) Old 12-25-2013, 09:34 AM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 884 Post(s)
Welcome to the forums.
I would post this question in the W211 forums we have here.
W211 E-Class - Mercedes-Benz Forum
Noodles is offline
