1985 Mercedes-Benz 300CD Turbo Oil Change - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-20-2013, 01:27 PM Thread Starter
Date registered: May 2013
Vehicle: 1985 Mercedes-Benz 300CD Turbo Diesel
Exclamation 1985 Mercedes-Benz 300CD Turbo Oil Change
Hey Guys!
I just went to get my oil changed, and for non synthetic, the guy quoted me over $125. Can you help me understand this? He said the oil was $9/quart more then normal oil, and the canister was $24 more then the base price of $39 for an oil change.
I felt like he was trying to pull a fast one, so I walked out. Any input would be helpful.
Car is a 1985 Mercedes-Benz 300 CD Turbo
pologirl is offline
post #2 of 6 (permalink) Old 12-20-2013, 07:19 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 176 Post(s)
Rip Off
At $8/qt you should get synthetic oil. The engine holds a little less than 8 quarts. The oil filter is in the $10 to $12 range.
This is a simple job that you should consider doing yourself. With the use of an inexpensive vacuum oil extractor, you can do the entire job from the top of the engine compartment without even crawling under the car and not spill a drop.
rocky raccoon is offline
post #3 of 6 (permalink) Old 12-20-2013, 07:30 PM
Kajtek1's Avatar
Quoted: 1199 Post(s)
Go to walmart and buy 2 jugs of 5-qarts M1 0-W40 for about $25 a piece
Kajtek1 is offline
post #4 of 6 (permalink) Old 12-21-2013, 12:36 AM
Date registered: Jul 2005
Quoted: 1019 Post(s)
For a diesel would he be better of with the 5w40 ESP Mobil? Or is that just for the newer diesels?
Noodles is offline
post #5 of 6 (permalink) Old 12-21-2013, 05:02 AM
~BANNED~
Date registered: Feb 2009
Vehicle: 1993 400E
Quoted: 419 Post(s)
The ESP is for newer diesels with particulate filters.
ESP = Emission System Protection
In the OM617 use Chevron Delo 15W40 or one of the
Synthetic 5W40 diesel oils in very cold climates.
As mentioned, this is a very easy DIY job.
Clarkz71 is offline
post #6 of 6 (permalink) Old 12-23-2013, 03:27 PM
Date registered: May 2010
Yes, if you have the room to do oil changes buy a Mityvac 8 qt. oil extractor. It will pull the oil up thru your dipstick real quick when the oil is nice and warm. Just remember to buy a good German filter, replace the o-rings on the rod that is inserted into the center of the filter if they are not new. Most shops will not do the o-ring replacement. Delo is good oil for your climate.
John
vanagonjon is offline
