2001 S class S320 diesel wont crank - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-29-2013, 11:08 AM Thread Starter
Date registered: Nov 2013
Vehicle: s class 320
Hello, I have a 2001 S class S320 diesel, has been sat for around a year, now wont crank, all drove fine prior to standing.
Fitted new battery, fuel level 1/4, remote opens/closes doors and arms/disarms alarm fine, turn key but wont crank.
All electrics on car work and don't dim when go to cranking position on key.
Initially, car started, moved 10meters to blow tyres up while ticking over cut out and now has the none start symptoms.
Have tried starting in park and neutral positions and wiggling gear selector but no joy.
Brake lights work and releases from park when press pedal so assuming stop light switch isn't the fault.
On speedo display shows 0 malfunctions.
Im a little stuck now where to go, if anyone has any ideas all be greatly appreciated.
Thank you!
scottydouk is offline
post #2 of 6 (permalink) Old 11-29-2013, 04:40 PM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Please give us more info?
Where is Kent?
I have not hear about 320 diesel from 2001. but we are pretty limited with car supplies here in USA and even less in California, so not hearing about available models is nothing new.
2001 cars are digitally controlled, so when the battery runs low, the computer will not activate the starter. This is the symptom you have right now, don't you?
Welcome to the forum.
Kajtek1 is offline
post #3 of 6 (permalink) Old 12-10-2013, 01:58 PM Thread Starter
Thank you for the response.
Its a 3.2 turbo diesel S class.
Kent is in the united kingdom.
The battery is in a fully charged condtion.
Have checked fault codes with a snapon scanner, talks to all modules, ecm, abs, suspension etc, main codes in engine control module are glow plug faults, but im sure this wont cause these problems.
Have checked starter motor wiring, and have no cranking signal to the small two pin electrical connector, main battery supply is good and good ground to engine block.
Have checked all blade fuses on car and main power supply fuses in off side of boot compartment all ok.
Cant see any water ingress in the car or over any of the modules in the engine bay.
Is there any relays which could cause the fault I have?
Where to go next...........
Cheers
post #4 of 6 (permalink) Old 12-11-2013, 12:18 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
I believe this discussion would belong to the W220 forum but my advice would be to get hold of the starter motor related wiring diagram. Then you can measure if you have the start signal at the starter relay output (you said no signal at the starter motor solenoid), starter relay input etc.
I understand the key turns in the ignition slot but the engine does not crank. It should not be a key issue then. Can still be EIS, engine ECU etc. A good diagnosis with Star would be in place if it turns out to be no signal from ECU to the starter relay.
Diesel Benz is offline
post #5 of 6 (permalink) Old 12-11-2013, 08:32 AM
Kajtek1's Avatar
That topic belongs to diesel section
00ps WE DO NOT HAVE ONE
3.2 turbo diesel is the engine I did not hear about at all. Definitely not imported to US, where most of the members here reside.
I would try on UK forum.
Yes - they do have diesel section
Kajtek1 is offline
post #6 of 6 (permalink) Old 12-11-2013, 04:52 PM Thread Starter
which is the starter relay?
Cheers
