stuck in park ?? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 11-18-2013, 11:16 PM Thread Starter
Date registered: Nov 2013
Vehicle: clk 270 cdi auto "55" plate
stuck in park ??
hello forum memebers.i have a problem as my clk 270cdi auto 55 plate is stuck in park.i parked up & 2 hours later i went to set off&went to put it into drive & it would not slide into drive or any where else.i had been working on the car earlier in the day ,taking off the air filter box to clean up the area as i had an oil leak so i steam cleaned that area around the cat &turbo but it ran perfect after that & i did 2 trips after that with no problems,i also changed a few bulbs on the rear lights as i had a light fault showing up on the dash.i did pull out all of the fuses one by one in all of the 3 fuse boxes to check to see if the rear light problem was a fuse but it wasnt. also i had a warning light on the dash about the ESP not working could this be anything to do with the problem?
alf1956 is offline
post #2 of 8 (permalink) Old 11-19-2013, 12:02 AM
eric242340's Avatar
Quoted: 306 Post(s)
Use the search function and type in ESM.
ERIC.
eric242340 is offline
post #3 of 8 (permalink) Old 11-19-2013, 04:11 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 385 Post(s)
Originally Posted by alf1956 View Post
.....i did pull out all of the fuses one by one in all of the 3 fuse boxes to check to see if the rear light problem was a fuse but it wasnt.
Why did you do that? You might have caused a new problem. Don't you have a fuse chart? FYI, there are no fuses for the external lights.
Also, it's probably better for you to post any CLK problems to the W209 forum.
keyhole is online now
post #4 of 8 (permalink) Old 11-19-2013, 07:31 AM Thread Starter
stuck in park now sorted !
sorted the problem out today.it was a blown fuse in the fuse box under the bonnet ,fuse number 60 i think it was.it was really strange as i had taken all the fuses out trying to solve a rear light issue about 3 hours before so i never expected it to be a fuse when they were all ok just a few hours before
alf1956 is offline
post #5 of 8 (permalink) Old 11-19-2013, 08:00 AM
eric242340's Avatar
Quoted: 306 Post(s)
No this did not solve the problem my friend, like Arny says, I will be back
ERIC.
post #6 of 8 (permalink) Old 11-19-2013, 08:29 PM
keyhole's Avatar
Quoted: 385 Post(s)
[QUOTE=alf1956;6815137].....sorted the problem out today.it was a blown fuse in the fuse box under the bonnet ,fuse number 60 i think it was.
If it was fuse f60, that is a 40A fuse protecting the ESP/BAS control module (N47/5). High power fuses should not just 'blow' - there will be a reason for this, as Eric suggests above, and your replacement might not last long.
In fact, fuses should never blow unless there is a fault on the line.
post #7 of 8 (permalink) Old 11-19-2013, 11:48 PM Thread Starter
t was not one of the big high 40amp fuses it was one of the normal fuses next to it which was 10amp
alf1956 is offline
post #8 of 8 (permalink) Old 12-18-2013, 10:43 AM Thread Starter
just to update everybody the fuse has not blown again & all is fine
alf1956 is offline
