ESP module Kaput! (supposedly) - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-16-2013, 02:17 PM Thread Starter
waco's Avatar
Date registered: Feb 2011
Vehicle: Silver 99' E430 Sport
Question ESP module Kaput! (supposedly)
:sigh: So, my actual module is supposedly junked.
What if...I bought a module with the same exact part number from the same exact car (options and all) and installed it? Would it still need coded? Please say no! Who could code it if not? I some reason doubt the dealership would
waco is offline
post #2 of 6 (permalink) Old 10-19-2013, 03:56 PM Thread Starter
waco's Avatar
Fixed!!!! Sweet mother! Finally....so yes a used ESP module of the exact same part number will work, as for others I dunno. Found it on E-bay $59.99. Dealer wanted $1,670.87
waco is offline
post #3 of 6 (permalink) Old 10-19-2013, 04:39 PM
Date registered: Jul 2005
Quoted: 972 Post(s)
Nice find. Thank you for posting your success.
Noodles is offline
post #4 of 6 (permalink) Old 10-19-2013, 11:58 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
ESP operation might still be somewhat compromised. The point is that the ESP control unit is adapted to the specific sensors in the car (B24/2 ESP lateral acceleration sensor and N64 ESP yaw rate sensor).
According to MB workshop instructions, the control unit needs to be adapter when one of these sensors is changed. In this case both sensors have been changed (as seen by the new control unit).
This control unit does not need any other coding like change of parameters or VIN coding, which was clear from waco's experience already.
The sensor calibration consists of a simple "road test", this test just needs to be initialised first.
If ESP seems to react properly at corners etc. perhaps the sensors in this car are not much different from the donor car.
Diesel Benz is offline
post #5 of 6 (permalink) Old 10-20-2013, 12:19 AM
Kajtek1's Avatar
Quoted: 1166 Post(s)
DB keeps on amazing me. This is not really information any car enthusiast can drop from his sleeve.
How do you get all this?
Kajtek1 is online now
post #6 of 6 (permalink) Old 10-20-2013, 03:32 PM Thread Starter
waco's Avatar
I read somewhere something along those lines, but not nearly as well said nor explained. So with that in mind, wifey and I headed out on an empty stretch of road (Industrial Park). We had a whole list of tests...
A.10mph---No fault
B.40mph---No fault
Y. Try to slide sideways, ESP engaged---No fault
Z. Jam on brakes on wet road, ABs engaged---No fault
We then let it "sleep" for 30 minutes and started the testing over...
My reasoning was more to eliminate variables if it did throw a fault, but I was also hoping it would "learn"
waco is offline
