Problems with my 01 E430 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-30-2013, 05:02 AM Thread Starter
Date registered: Sep 2013
Vehicle: 2001 Mercedes E430
I bought this car recently from an auction and I'm trying to fix some problems but I'm having a hard time pinpointing the issues. Here's a list:
1. My rear passenger window will not do anything. It was up when I bought it and it will not move. Initially I assumed it was the motor but after reading a lot of forums now I don't know if it's the motor or the regulator. When I press the button I hear nothing. I would think that if the motor still worked, I would hear something.
2. When taking apart the door to inspect the motor, the directions I was reading said to disconnect the battery to insure there wasn't a short that would cause the airbag to deploy in my face. After having the battery unhooked for about 45 mins I hooked it up and went in. The next morning when I started the car I had several things happen: the bas, abs, and esp alarms came on; the 3 windows that do work still work but when I press the buttons down all the way to make the auto roll up, they stop in place; I just had a door latch fixed because the dome light would not go off when I shut the door. Now again it stays on and at the same time the headlights do not flash 3 times anymore when I lock my doors. I'm not sure what is causing this but I hope its a simple fix.
3. My malfunction light alarm triggers randomly when I hit my brakes. I had the bulbs burn out once so I replaced them. They worked fine for a day then the alarm triggered again. After messing with it for a few hours I ended up switching bulbs and carriers from the left and right sides and it worked again. Now a few weeks later I am getting random light alarms after pressing my brakes. There in no consistency with the alarm.
I hope someone can help me diagnose these issues. I do not have another $150 for Mercedes to diagnose the problem so I would like to figure this out alone. Thank you ahead of time.
Ssparks is offline
post #2 of 2 (permalink) Old 09-30-2013, 10:13 PM
Kajtek1's Avatar
Quoted: 1068 Post(s)
Welcome to the forum.
Your car is W210 body and we do have active section designated just for it.
You will find lot of info in stickies there about synchronizing windows, sunroof and ESP what will solve most of your issues.
Use only MB light bulbs. Other will trigger warning.
Kajtek1 is offline
