average life span of serpentine belts ? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 09-23-2013, 11:53 PM Thread Starter
Date registered: Nov 2010
Vehicle: 1995 SL 320, 2008 CLK 350
Some years ago a failed belt trashed my engine to the tune of $5000.
So now (with a newer 2008 CLK350) I look at it from time to time but it seems to be OK.
Well, eye-balling may not be the best way to forestall damages so the question is:
IS THERE A MILEAGE WHERE A CHANGE IS RECOMMENDED ?
Handbook is silent, so would it be 30,000, 35,000, or later ?? Any thoughts on this, any recommendations, experiences ??
Thanks for any input.
jack ullrich is offline
post #2 of 10 (permalink) Old 09-24-2013, 01:25 AM
Date registered: Jul 2005
Quoted: 1018 Post(s)
It can really depend on climate. Routine visual inspection is a good thing.
I do mine every 5-7 years. I also keep a spare in every vehicle seeing as MB serpentine belts can be hard to find in stock locally because I live in a very rural area.
Noodles is offline
post #3 of 10 (permalink) Old 09-24-2013, 03:29 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
I'm trying to figure out how a failed belt could have done $5,000 of damage. Unless you let the car overheat.
flyboyike is offline
post #4 of 10 (permalink) Old 09-24-2013, 03:45 AM
nathanD.rector's Avatar
Date registered: Jan 2013
Vehicle: 99 s320,and 83 300sd
Quoted: 217 Post(s)
look at the underside of belt,when cracks appear change it
1999 s320. and 83 300sd quit driving,people make me nervous
nathanD.rector is offline
post #5 of 10 (permalink) Old 09-24-2013, 09:47 AM Thread Starter
easy......... running along at 50-60, hearing a sudden noise up front, slowing down in traffic, and in 15-30 seconds stopping to investigate , and trouble has been cascading rapidly. This was on a 8 cylinder BMW 503 cabriolet, and all the aluminum and whatever started to warp.
Was a pity, after fixing it sold it for a few thousand, today the car is worth $130,000, one of only 164 ever made. Still in mourning.
post #6 of 10 (permalink) Old 09-24-2013, 10:41 AM
flyboyike's Avatar
Quoted: 69 Post(s)
Interesting.
post #7 of 10 (permalink) Old 09-24-2013, 10:14 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
This is no longer really reliable due to the improved quality and longevity of belts. The problem is that the teeth wear away and may start slipping.
If you go to the gates rubber website, you can order a little gauge and they'll send it to you for free. You place it in the grooves and it shows you the wear. Then you know to replace it.
I recommend changing the idler pulley at the same time. A cheap part, less than the belt, they are usually shot by 80K or so (the belt is usually done by then, too) and when they fail they may cause lots of collateral damage...as well a stranding you.
Good luck.
Check Codes is offline
post #8 of 10 (permalink) Old 09-24-2013, 10:56 PM
Kajtek1's Avatar
Quoted: 1198 Post(s)
I don't buy new cars lately, but have good feeling that at least couple of belts I replaced at over 200,000 miles were original.
It is belt quality that counts.
When I was doing serious engine work on W124 with 293,000 miles on it, I decided to replace replace belt as well as the old one could be original. Bought new belt at reputable European indy warehouse near by and put it on. The belt show a string sticking out after 100 miles. I cut it off and ignored. About 200 miles later I hear big noise under the hood and discotheque lighted up my dashboard.
All I found under the hood was a mile of string wrapped around the engine.
Old belt went back.
Kajtek1 is online now
post #9 of 10 (permalink) Old 09-29-2013, 01:32 AM
Date registered: Nov 2003
Vehicle: 2004 CLK320
Quoted: 5 Post(s)
I just replaced the serpentine belt a few months ago. Based on dealership recommendations, they also replaced the filter pulley, belt tensioner and crankshaft pulley.
At the time the car has 166k miles.
mis3 is offline
post #10 of 10 (permalink) Old 09-29-2013, 03:28 AM
Quoted: 217 Post(s)
I changed mine at 128,000 miles
