Air conditioner - one side blows cold, other no a/c - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-08-2013, 08:00 PM Thread Starter
Date registered: Aug 2012
2002 E320
As the title says, the passenger side blows cold while the drivers side blows ambient air. I'm guessing some door is either not opening or closing as it should. I know the doors are pneumatically controlled. Any one have the problem? Problem in the pneumatic switcher?
pcolapacker is offline
post #2 of 3 (permalink) Old 09-08-2013, 10:10 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
It would be essential to know where you come from (or where the car comes from), or to have more info about the car. In Europe a 2002 E320 would be a W211 model (you could have asked from the W211 forum then). Within NA it would likely be a W210 and you would find all the necessary info from the W210 forum.
I assume the car is a W210 because you are referring to vacuum controls, door locks on a W211 are electric.
The HVAC systems are also quite different
I doubt there is any connection between the door locks and heating. Most likely the basic duo-valve issue that is well known already from models before W210.
More reading here: W210 E-Class - - Mercedes-Benz Discussion Forum
Welcome to the forum!
Diesel Benz is offline
post #3 of 3 (permalink) Old 09-08-2013, 11:43 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
If your car is W210 body, you will find AC testing procedure in stickies on top of W210 section.
Do the sensor and errors readout and post in the section for interpretation.
Welcome to the forum.
Kajtek1 is offline
