How to shift in neutral with engine off - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-29-2013, 10:46 PM Thread Starter
Date registered: Sep 2012
Vehicle: x164 2008 GL320 Cdi
Hi, I've recently had a major problem with my R320 Bluetec 2009 and the engine won't start. The transmission has an electronic paddle shifter and since it won't start, I can't put it in neutral. I'd like to know if there's a way to bypass the electronic system and mechanically shift it in neutral so I can tow it to the dealer or at least put it on a trailer to get it there.
I've read something about a free wheeling adapter, but that's expensive and it won't get there soon enough. Is that the only option?
Current: 2009 R320 BlueTec
Past: 2008 GL320 CDI
iLikeRedBull is offline
post #2 of 3 (permalink) Old 08-29-2013, 11:41 PM
Kajtek1's Avatar
Quoted: 1168 Post(s)
Check your manual. Earlier triptonic shifters would allow pencil trick to shift locked lever.
Good towing will come with freewheeling adapter.
Kajtek1 is online now
post #3 of 3 (permalink) Old 08-30-2013, 04:37 PM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160
Quoted: 474 Post(s)
Key in position 2, press and hold brake pedal, select N using shifter paddle, release brake pedal. Do not remove SmartKey. Battery must have sufficient voltage.
There is no pencil trick for the column-mounted paddle shift.
DrX is offline
