How do you remove these? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-20-2013, 07:00 PM Thread Starter
Date registered: Aug 2012
Trying to remove the black plastic clips inside fender on a 2006 ML500.
There are plastic circular clips/screws. I tried with a plastic pry bar but they aren't moving. How do I get them to pop out?
Looks like this HERE
Thanks
ICloud22 is offline
post #2 of 4 (permalink) Old 08-20-2013, 11:12 PM
Kajtek1's Avatar
Quoted: 1225 Post(s)
Can't tell from the picture, but MB often is using wedges to anchor the pegs.
In small sizes you need to push center pin and catch it on other side, on bigger you need to pop the center wedge a bit and than pull the peg.
Kajtek1 is online now
post #3 of 4 (permalink) Old 08-21-2013, 01:54 AM
Date registered: Jul 2005
Quoted: 1053 Post(s)
Yes, the center pin has to be pulled up and then the clip will release. The center pin expands the ends of the clips outward so they stay in place. So when the pull is pulled up they relax and the whole fastener comes out pin and expanding end.
Noodles is offline
post #4 of 4 (permalink) Old 08-21-2013, 08:10 AM Thread Starter
Ok, thanks. Got it. I had to use a very small flat head to get it started then the yellow pry bar did the trick. THanks!
ICloud22 is offline
