04 CLK500 temperature gauge reads 100 degrees Celsius - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 08-18-2013, 05:17 PM Thread Starter
Date registered: Jul 2013
Originally Posted by Kajtek1 View Post
Good luck figuring it out.
MB never had green coolants. The older coolants were pee color, the new ones are pretty blue.
I'll have to withdraw some to figure out it's true color, but until then, how do I replace the fluid? Is it a difficult task to do?
rsoheilian is offline
post #12 of 18 (permalink) Old 08-18-2013, 05:21 PM
Kajtek1's Avatar
Quoted: 1166 Post(s)
You will find about 1000 recipes, but what I do is buy about 3x the system capacity of distillate water and radiator cleaner.
I usually add cleaner to the old fluid and drive with it for few miles while using heating.
Drain using radiator drain, refill with DW and drive again. Repeat 2 more times before refilling with MB coolant. I don't have to worry about low freezing point, so I usually buy 1 gallon of MB coolant and top it off with DW.
Kajtek1 is offline
post #13 of 18 (permalink) Old 08-25-2013, 08:36 AM Thread Starter
So, I was wrong the coolant was that yellowish color that you stated, and it was genuine mercedes coolant, but even then I wanted to take extra precautionary measures, so I had another coolant flush. The mechanic switched out the coolant with the blue MB coolant, but it still hits 100 when stationary and through traffic.
post #14 of 18 (permalink) Old 08-25-2013, 08:52 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 374 Post(s)
My CLK service manual advises to change the coolant at either: 15 years or 115k miles.
Why are you changing yours?
keyhole is online now
post #15 of 18 (permalink) Old 08-26-2013, 08:12 PM
Kajtek1's Avatar
It was about 2003 or 2004 when MB started to install chem pack in coolant reservoir, therefore extending the coolant life to 15 years.
Those models with no chem pack still have 3 years intervals. I am extending it to 5-6 since I have no freezing, but that is about all.
Now rsoheilian I have to repeat my advise to get infra-red thermometer and do some troubleshooting.
Kajtek1 is offline
post #16 of 18 (permalink) Old 08-28-2013, 11:32 AM
Date registered: Jul 2012
Vehicle: 1967 250S, twin Weber carbs, automatic trans, power windows, A/C, R134a conversion
Note: I believe he referred to his OIL temperature, not his engine coolant.
Kitaka is offline
post #17 of 18 (permalink) Old 08-28-2013, 01:22 PM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160
Quoted: 474 Post(s)
The shop lied to you about OEM fluids.
Note to anyone checking their coolant: MB coolant is blue with a greenish tint. The shop didn't lie.
DrX is offline
post #18 of 18 (permalink) Old 08-28-2013, 02:54 PM
keyhole's Avatar
Quoted: 374 Post(s)
No - the engine oil temperature is not displayed at the cluster. The coolant temperature is.
