Airmatic - where is the relay and 40A fuse ? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-09-2013, 01:29 PM Thread Starter
orm
Date registered: Aug 2013
Vehicle: cls 320 cdi
Hi, I'm trying to find the location of the relay and fuse for a CLS 320 cdi as per the below:
http://www.benzworld.org/forums/c219...use-relay.html
Searched all over and seems to indicat the passenger footwell for various models for the fuse and the engine bay for the relay. I cannot see either, any suggestions - please help!
orm is offline
post #2 of 2 (permalink) Old 08-10-2013, 11:03 AM Thread Starter
orm
ok found relay k67, it was in the top left of the fuse box rather then the bottom left.
Took the relay out and tested the relay socket for +12v on the switching contact - it was ok and showed 12v - so this means fuse 74 in the prefuse box must be ok. Shorted out the switching circuit (the relays job) and the pump runs.
I started the car and linked out the relay to run the pump - the pump runs but the car does not rise
I checked the signal to the relay socket and would of expected 12v telling the relay to switch and the pump to run - however I didn't get anything, 0v
So it seems like the relay is not getting its signal to tell the pump to run.
Any ideas what I should try now ? Thanks
orm is offline
