2005 C230 no compression - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-08-2013, 12:32 PM Thread Starter
Date registered: Jan 2013
Hi i got 2005 c230 start and stall with no restart found plugs fouled with gas. The car has 90000 miles on it the plugs look to be factory. now with a new set of plugs and fuel dryied out of cylinders car still will not regain compression.Can anyone help?Has good oil and past history.
lmar1171 is offline
post #2 of 7 (permalink) Old 08-08-2013, 01:30 PM
Date registered: Jul 2005
Quoted: 1009 Post(s)
Compression does not just disappear. All of the cylinders at once is even stranger.
I am assuming you checked all cylinders. What tool was used to determine the compression was gone from cylinders?
Noodles is offline
post #3 of 7 (permalink) Old 08-09-2013, 04:05 AM Thread Starter
Yes all cylinders loss and spark plugs soaked. was a little rough running was told the day before but not bad and when I went to start in the am no start fuel fowled.the car has been starting with a little rough idle at first in the morning but would clear right up.a little puff of raw fuel like the plugs just could not burn to well old age .when I pulled them they looked vary well like there was old gas in the car and smells like it but when I took a fuel sample its good and the car never sits. I think he may of got some bad gas but not there now.if a c230 losses compression from no spark and floods the cylinders is it that hard to just regain compression in these like a jag or if that was all the car should have started after fuel and plugs where changed?
lmar1171 is offline
post #4 of 7 (permalink) Old 08-09-2013, 06:28 AM
Do you mean it has lost fuel pressure?
If the compression in all cylinders is gone the motor has a serious issue.
Noodles is offline
post #5 of 7 (permalink) Old 08-09-2013, 07:11 PM Thread Starter
no I have spark and fuel no compression. due to old plugs losing spark and then fuel fouling cylinders. a guy on line said they where known to run rich and when the plugs get old they will fuel foul. causing no compression but said it was hard to get it back sometimes but could not answer how. I tried oil in them still no luck.
lmar1171 is offline
post #6 of 7 (permalink) Old 08-10-2013, 03:23 AM
I did not know that. I wish I had better help for you. I would post your problem in the W203 forum for your model. There are a lot of smart C class owners that may be able to help.
W203 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum
Noodles is offline
post #7 of 7 (permalink) Old 08-10-2013, 04:14 AM
Date registered: Jul 2011
Vehicle: 05 C230 Kompressor Sedan--Mars Red,2001 Mazda Miata LS, & 2011 GMC Sierra Z-83 pick up
Just throwing this out there..... Are you sure you got the correct plugs and that they are seating (read that as sealing and giving you compression) properly??? I had a 1974 Firebird 400 many years ago that had a similar problem. Jon
2005 C230 Kompressor--Mars Red-- C590
2001 Mazda Miata and 2011 GMC Sierra Z-83
jon winship is offline
