Putting Hella fog lights to a Bull Bar - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-01-2013, 12:47 AM Thread Starter
vantvi's Avatar
Date registered: May 2004
Vehicle: 2004 Mercedes Ml 350
I have a 2004 Mercedes Ml 350 with a oem bull bar and was wondering if you can put hella fog lights mounted on the bull bar. If you can can you wire the hella fog light to the fog light on the bumper so that there are 4 fog lights running at the same time, and is there a oem bracket so you can mount the fog lights to the bull bar?
vantvi is offline
post #2 of 3 (permalink) Old 08-01-2013, 12:58 AM
Mars478's Avatar
Date registered: Nov 2011
Vehicle: Black 1999 ML320
Quoted: 35 Post(s)
You may be benefitted by posting this question in the W163 ML 98-05 section of the forum.
And the answer to this question is yes, you can get the Hellas and easily just tap into the wiring that is available to the fogs in the bumper, there even may be another wiring harness to attach separate lights to but I am not sure. I would just run a wire from the lower grille in the bumper to the bull bar mounted lights.
I assume you mean like this?
ML320: 1999, black, in dash iPad Mini, LED tails, Facelift headlights with Hella E55's, 6k bulbs, RallyCrossed, and 250k and counting.
And a few other, less reliable cars...
Mars478 is offline
post #3 of 3 (permalink) Old 08-01-2013, 01:11 AM Thread Starter
vantvi's Avatar
Yes, and would you have to drill into the front bar, or is there a mount you can buy. I tried buying a mount but the 1.75 and 2 in. mounts would not fit the bull bar.
vantvi is offline
