1999 C280 engine fan clutch bad/diagnosis? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 07-27-2013, 04:59 PM Thread Starter
Date registered: Jul 2013
Vehicle: Mercedes Benz C280
Hi , al d here/ Maryland. When my electric fan kicks in at around 95 degrees or so, I can stop it with my finger. The temp, of course, will rise to a biy under 100 when the orange coolant light lights up. This of course is all at idle after a good run. Bad clutch? Thermostat and temp sensor. Next to it brand new. Thoughts? Bad clutch/ why even have a clutch? Diagnosis? All fuses Ok; but relays, I dunno. Thanks dudes,
Afdefelice is offline
post #2 of 11 (permalink) Old 07-28-2013, 02:38 AM
eric242340's Avatar
Quoted: 295 Post(s)
Yup bad thermal clutch. The fan speed should increase as the engine warms up and the temp increase tightens the clutch, it should take your finger off so do not keep testing it this way, we usually use a rolled up newspaper, a good fan clutch will shred the paper.
ERIC.
eric242340 is offline
post #3 of 11 (permalink) Old 07-28-2013, 06:51 AM Thread Starter
Thanks plenty. Easier to just replace whole fan/ motor /clutch module rather than just the clutch? What would you do. I understand the latter is a pain. Thanks again, and plenty. Special coolant for this special German iron? Then, I am onto sp plugs: you recommend the Bosch 4 ground electrodes?... love to keep this iron rolling as well as it can
Again, much appreciated.
post #4 of 11 (permalink) Old 07-28-2013, 06:55 AM
eric242340's Avatar
Quoted: 295 Post(s)
Now you have confused me, there is no motor on a fan clutch. And for plugs use standard benz rec plugs, the four pin is too high a heat range and will cause problems later on.
ERIC.
post #5 of 11 (permalink) Old 07-28-2013, 07:03 AM Thread Starter
No, I, of course , was referring to the six cylinders in front of the fans :-) . I should bleed the air out of the upper hose/ tstat housing, no,? How? Special coolant? Have a great day dude. You have been seriously helpful
post #6 of 11 (permalink) Old 07-28-2013, 07:24 AM
eric242340's Avatar
Quoted: 295 Post(s)
With Benz unlike BMW there is no real need to bleed air, just leave the header tank top off and bring the car up to working temp, once air bubbles stop put the top on, oh and put the heater on full blast inside the car whilst bleeding, this will ensure there is no air lock in the heater matrix. Benz have their own coolant but 99% of coolants will suffice with this model.
ERIC.
post #7 of 11 (permalink) Old 07-28-2013, 07:55 AM Thread Starter
OK; got it. I think I will just buy the whole fan/motor/ clutch module. Relays, too? They ever go bad?
post #8 of 11 (permalink) Old 07-28-2013, 08:14 AM
eric242340's Avatar
Quoted: 295 Post(s)
I am begining to think you are talking about the auxilliary fan and not the thermal fan, if so just buy the whole unit, forget the relay as the fan is getting power. Thermal fans do not need power and work on heat, so you mean the aux/electric fan.
If this is the case and the fan does run but does not go to high speed then the module is the cause so change the module first.
ERIC.
post #9 of 11 (permalink) Old 07-28-2013, 08:35 AM Thread Starter
The slow spinning fan is closest to the eng block. I should let it get as hot as it will, to if it goes to high? But the orange fluid level/ (temp?)) Light be have come on. If no shift to high, I will replace that module. Where is it? I do not think I ever heard the roar of the main fan as it kicks in. I am starting to think both the aux fan module and the thermal clutch main are shot. If so, amazing how efficient the MB cooling is. Another clue: the AC is not "conditioning".
post #10 of 11 (permalink) Old 07-28-2013, 08:50 AM
eric242340's Avatar
Quoted: 295 Post(s)
OK we are getting somewhere, the clutch fan needs changing, that is a given. Now as to the electric fans you need to fix the air conditioning first as these fans/fan depending on model, some models have two and some one. The fan/s are turned on according to AC pressure via a sensor on the dryer. So no AC means only one stage on the aux fan/s. Get the air con tested as it may be low on freon gas.
ERIC.
