Replacing 96 C280 AC compressor - need oil amount - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-24-2013, 07:43 AM Thread Starter
Date registered: Jul 2013
Vehicle: 1996 C280 6 cylinder
Hello,
I am ready to replace the AC compressor (and drier) in my 96 C280 (6 cylinder), but cannot find out the amount of oil to leave/put in the new compressor.
The instruction sheet with the new Denso compressor says to measure the amount of oil in the old one, but the old one leaked significantly.
Any thoughts on how to proceed? Thanks!
Eric
Happy C280 Owner is offline
post #2 of 5 (permalink) Old 07-24-2013, 01:21 PM
Date registered: Jul 2005
Quoted: 971 Post(s)
On my 99 ML it is on a sticker under the hood.
According to alldata depending on the compressor it is 4-5.2oz, but that sounds like too much. Usually a new Denso compressor comes with oil pre-measured for it.
Noodles is offline
post #3 of 5 (permalink) Old 07-25-2013, 10:25 AM Thread Starter
Thanks Noodles
Noodles,
I have attached a Mercedes AC capacity sheet that I just found online. Not much help from the sticker as it says 1.9 lbs(!), but the attached Mercedes AC capacity sheet helped alot. You might be able to use it as well.
My compressor is the 7SB16 (page two, part way down, 3rd column) and it says 120 cc (4.06 fl oz).
Thanks again for the help! I very much appreciate it. Now to the real adventure under the hood.....
Eric
File Type: pdf 2012-05-16_022242_refrigerant_compressor.pdf (58.0 KB, 81 views)
post #4 of 5 (permalink) Old 07-25-2013, 12:27 PM
Quoted: 971 Post(s)
1.9 lbs is the freon.
Based on your compressor model the 4.06oz is the oil amount for a new compressor.
Noodles is offline
post #5 of 5 (permalink) Old 07-25-2013, 02:03 PM Thread Starter
Thanks Noodles,
i appreciate the input regarding the 1.9lbs. I hadn't considered the freon!
Eric
